Oil Pressure Gauge braided line failure
twas_brillig
Moved the BJ7 Healey out of 'winter' storage in early June; brakes real iffy (fluid leakage?) and the engine puked oil the whole 'move around from behind garage to driveway'. Dang, as the only problem last fall was that the o/d had quit.
Turns out that oil was gushing out of the upper end area of the braided line from the block to the fitting taking the oil pressure up to the oil pressure gauge.
I've pulled the line and there was nothing obviously wrong with it nor the connection (that I could see). I've ordered a replacement braided steel line, but: is this a common problem? any advice on the wrench sizes that work (Imperial worked on the engine end; 13 mm was just a hair too tight on the upper end).
Wisdom solicited!
Doug
Keoke
Yes failure of that line is fairly well known. I had mine rebuilt and the rebuilder suggested that i use high pressure unbraied hydraulic hose becaise the braid carries engine heat to the hoses rubber adding to the potential for failure.--Fwiw-Keoke
Patrick67BJ8
Not to discount what your mechanic said, but aircraft use braided hoses and operate under more extreme heat than our Healeys. FWIW
Keoke
Yep Patrick, but they do not fly the same hose for 40 years--- :laugh:
T
twas_brillig
well, gosh darn and dang: ordered the replacement braided hose from AH Spares in Jolly Olde and it was here a week later, but I didn't get 'round tuit until this past weekend. And found that there was a mis-match with threads/diameter when trying to thread it onto the male fitting on the metal tube to the oil pressure gauge.
Checked with AH and they advised that their's was BSP, the same as it always had been. Their only thought was that there had been a leak there at some point, and a PO had replaced both the tube and braided as a set. I'm the third owner; the first owner had apparently had the speedo replaced at 10 000 miles so maybe?? I've ordered the tube, but I'm curious as to whether or not anyone has any thoughts?
BJ8Healeys
I believe the braid is provided more to protect the hose from chafing, but the stainless steel braid would reflect radiant heat from the engine, whereas the black rubber hose would absorb it. Convective/conductive heat from the oil is going to get to the rubber whether there is a braid or not. My conclusion would be that from a heat point of view, it's better to have the braid than not and the protection from chafing is a bonus.
T
twas_brillig
Update: replaced the metal tube from the oil gauge along with the braided hose; turns out that the metal tube was just fine and the threads were compatible, but there must have been some sort of little ding/whatever such that the new hose wouldn't thread on while the connection was in place (and a bit awkward to reach). So, caused myself a bunch of extra work, and I'll have to spend some time next Spring trying to get the (unnecessarily purchased) new tubing bent around so it looks more or less stock.
So, got the oil leak fixed and the brakes working at the start of September, just in time to give the grand-daughter a ride home from her first couple of days at a new school in Grade 7.
But next year!
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
