Oil Pressure-Bugeye Sprite
tony_herbert
Hi y'all
I am new to the forum and jump in straight away with a question. I have a 1959 Bugeye Sprite which has been modified with a 1275cc engine and upgraded front suspension and disc brakes. While driving this weekend I noticed the oil pressure dropped to anywhere between zero and 20lbs, while occassionally jumping up to 40lbs.
Is there a simple way to check to see if it is a faulty gauge/switch or pump failure? The car is in the garage until I get this sorted out!
Thanks
Tony
Buy a cheap gauge from autozone and compare. 20 lbs fluctuation is common, but going less than 20 psi is not so good.
Gerard
It's very unusual for an A-series, especially a 1275 to have less than 40-45 PSI, even at idle. You could just have a faulty pressure relief valve (plug below oil feed between block and oil filter), but you should look into it since it could also indicate a bad bearing or weak oil pump. Rule of thumb, 10PSI / 1000 RPM, so anything less that 20- 30 PSI is cause for concern.
LulusBugeye
I had a strange incident this weekend. I was out in my 1960 sprite (948, non working Tach) and after an hour I came to a stop and started smelling fuel and noticed Oil Pressure at about 10PSI. It's normally at 25-30 at Idle. As soon a I accelerated it went into the normal 40ish range. I came to another red light and PSI dropped like a rock again.
Got the car home and popped the hood to notice a major fuel leak coming from the hose that connects the two Carb Float Bowls together. A new hose is on order from VB, but my assumption is that lack of fuel caused extremely low RPM's at idle which hampered the oil pump and therefor low pressure. I hope I am right and that there is not a greater Oil pressure issue at hand. Everyone keep your fingers crossed.
But Tony, I am sure you and I both (as newbies) had that same feeling of our heart's dropping along with the Oil Pressure!!!
Bayless
That may be possible but I think not likely. Dropping the idle that much would be more likely to stall it completely. Even if not you certainly would have noticed it. Fix the leak and try again but be prepared for a deeper investigation.
TulsaFred
I've had this happen to me, due to low rpms
aeronca65t
With the second problem, be sure you don't have a ripped fuel pump diaphragm. The 948 uses a mechanical fuel pump. If the diaphragm rips, it may allow fuel to enter the engine sump....causing fuel smells and low oil pressure.
With the original poster's question, I would do as Trevor has suggested. Buy an inexpensive oil pressure gauge. Most of these gauges have a 1/4-NPT thread, so you can thread the gauge directly into the engine block, eliminating the line that normally goes from the engine to the gauge.
T
tony_herbert
Just got my sleeves rolled up. Guess what? Low oil pressure=low oil level!
Just needed to top up the oil and make sure I keep an eye on it in future.
Thanks
LulusBugeye
As for my issue - my oil was a little low. I topped it off, and replaced the Carb Hose and am now without issue. I have an electronic fuel pump so am ok on the diaphragm issue, but now I am constantly monitoring fluid drips and leaks by changing my cardboard out after every drive to inspect. Since I dont have jackstands yet, this is the best way for me to monitor locations of drips without getting under there. It would be great if someone had a graphic that showed the footprint of the car with various spots called out indicating what a leak could be from based on location of drip.
bug_sixty
oil leaks are sort of like a water leak in a house the drip point could be "miles" from the source.. unless it's coming in buckets.. live with it or... do a rebuild including a line bore with a new rear plate... thinking, a cheap fix is the valve cover gasket.. Might try that and since it is at the top of the chain, you can certainly see the results conclusivly.
bug_sixty
other issue is internal pressure build up..not to be overlooked..Make sure you have an operational PVC set up as in OEM or one that works.. Not doing so can cause leaks just about everywhere on the engine!
Jim_Gruber
Concur, when I got Bugsy home he had the crankcase vent plugged and the other end of the vacumn line plugged with a 3" 3/8 extension bar crammed in the end of the hose. Engine ran but pumped oil out the rear seal like you would not believe. I thought I bought the Exxon Valdez.
Replumbing and following the pics in the MOSS manual got correct negative pressure in crankcase, rear seal leak slowed to a single drip when I stop and 3-4 other small drips that is a case of Bugsy marking his territory. Engine needs a valve job and rings I know, but seems to run fine, still has lots of pep, starts too quickly since carbs were worked on as in let it crank and crank and don't pull out the choke so you can get some oil pressure built up, is not smoking, and 20W50 can be had for a whole lot less than a rebuild. For the amount of driving most of us do with these cars unless it's really smoking or making nasty noises get in and drive. Thse engines have taken a tremendous amount of abuse over the years and with a little care and maintenance will continue to be a sweet little powerplant. Get in, have fun, and drive it like you stole it as Frank used to say.
R Bugeye oil pressure line Spridgets 9
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
E Bugeye Oil Pressure Gauge Spridgets 5
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
