TR2/3/3A Oil pressure readings
CJD
Above 2000 rpm you should set the pressure regulator to 70psi. Idle, then, shows the amount of clearance in the engine. You should have no less than 10psi. Anything greater than 10 is gravy. If you do drop below 10psi, you can use thicker oil to stretch a rebuild.
Then, remember that the dash gage may or may not show the correct pressure. If you are really curious, it would be best to use a decent gage tapped into the line.
K TR2/3/3A Oil pressure readings Triumph 10
K TR2/3/3A Oil pressure gauge readings? Triumph 9
K GT6 Spitfire oil pressure gauge readings? Triumph 4
Guinn Oil pressure gauge readings MG 14
Bret Weird Oil Pressure Gauge Readings? Other Cars 7
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
