Bypass hose...
rjfoster03
Member
I need to replace the Bypass hose that connects on the top of the water pump.
It may seem like an easy question, but I wanted to see what the best way to replace the bypass hose. To remove the water pump, what is the easiest way to do this. The area is tight to get to, so should additional things be removed?
Thanks for any suggestions.
I imagine it can be done, but the only way I have ever done it is when the head was off.
The least that I have ever done to change a waterpump (along with the hose) was to pull the radiator, it was still a bit tight but doable.
BillM
No no. It is doable, just use a small peice of hose the right size from your local car parts place. Cut it just right, note the slits in the tubes it must go over. A bit of goose grease and a couple of screwdrivers and it can be done.
Of course Ray, that would word easier and is what Miss Agatha is useing but you have to order those. Regular hose is available localy.
Those corrugated hoses have a nasty reputation in the Mini community. As an alternative, I have often heard of a method very similar to what Jack suggests.
Buy a short piece of quality 1/2" heater hose. Cut it slightly shorter (1/4"-3/8") than the distance between the head and water pump. Remove all remnants of the old hose and take your new short piece of hose and fold it in half using vice grips. Put a little non-hardening sealant on the inside of each end of the hose (as a sealant and a lube) then push the hose against the two nipples as you manipulate the vice grips to release the hose in place. The worm type hose clamps that you can completely open are then fit to the hose to secure it.
I personally have not had to do this but have had several people I trust tell me that this method will work to get the bypass hose in place without pulling the head or the water pump.
Hehe, it will work. I had forgotten about the vicegrips. I did this way back in the 60s. Heck I didn't know any better.
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
R TR2/3/3A Thermostat and bypass hose Triumph 15
B TR2/3/3A bypass hose Triumph 11
P 1275 bypass hose???? Spridgets 5
L TR2/3/3A bypass hose Triumph 3
J TR4/4A TR3, TR4 bypass hose needed , NAPA #? Triumph 2
Doug Sabbag TR6 Ammeter blown.. bypass? Triumph 10
M TR5/TR250 Bypass valve Triumph 27
A T-Series MGTD oil pump bypass valve MG 0
Gliderman8 TR6 Rheostat bypass Triumph 1
S TR6 Stromberg Bypass Valves - Question Triumph 11
C TR6 Seat belt warning bypass for new harness. Triumph 6
L TR6 Bypass valve adjustment Triumph 1
T TR2/3/3A Water Pump Housing Bypass Triumph 11
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
sundown TR6 1973 TR6 bypass valve Triumph 1
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
D Overdrive bypass switch Austin Healey 1
K TR2/3/3A Paging TR3driver re blocked bypass and Shaller pdf Triumph 1
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
E 1275 Water bypass nipple Spridgets 11
V ZS Carb Bypass Done Triumph 1
V TR6 TR6 ZS Bypass kit Triumph 18
wangdango TR6 '76 TR 6 stromberg bypass valve? Triumph 1
19_again Gas bypass-low rpm's MG 5
A bypass vs no bypass Spridgets 10
E 1275 Cylinder Head Bypass Nipple Spridgets 4
Paulus Stromberg bypass issues Triumph 4
K TR2/3/3A TR3 Cooling...Blocking the Bypass Triumph 5
jerrybny Bypass Valve Assembly Triumph 2
B T-Series bypass hazard switch MG 17
Y Oil pressure ignition bypass MG 3
S Spitfire Cyl head coolant hose fitting Triumph 1
KVH General Tech Hose Clamps Triumph 5
R MGB 1972 MGB Defroster Hose MG 2
T Exhaust Pipe Hose Austin Healey 9
LAW75 Concours: Original Gas Hose Austin Healey 12
Patrick67BJ8 Fuel Hose Decals Austin Healey 16
T Radiator Hose Size Austin Healey 2
petnatcar Breather Hose Conversion Austin Healey 2
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
drooartz Hose from water pump to head, remove water pump? Spridgets 12
alexisrexx TR6 Engine Hoses Kit or Hose by the foot? Triumph 6
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
G Original clamps for Petrolex hose Austin Healey 9
edkap2002 TR6 lower radiator hose fitting Triumph 2
M TR6 Clutch Hose, SS Vendors Triumph 2
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
