WEBER DGV - what fuel pump / regulator do you use?
tosoutherncars
Hi all,
Just wondering what fuel pump and/or fuel pressure regulator everyone is using with their DGV/DGAV/DGEV setups. Details, impressions?
As I understand it, the DGVs require low pressure (2-4 PSI?) and high volume. I have left the mech fuel pump in for now, and put in a Holley low-pressure regulator. Haven't driven it enough to be able to give a verdict... I have to imagine that that much back-pressure must be hard on the pump. From a bit of web research, seems like some suggest the low-pressure Carter 'green' pump, mounted down by the gas tank?
Thanks in advance,
Duncan
68Sprite
Go with the Carter P4070 it is perfect for the Weber carb setup. I'm running one on mine and have been very pleased. No regulator on this setup by the way.
Platinum
I just recently put a Carter P60504 in-line pump on the Alfa and so-far it's been fine. Plenty volume, low pressure. Twin DCOE's, BTW.
tosoutherncars
tosoutherncars
Well that was lucky... ebay auctions ending in the middle of the night, when I was the only MG-addicted insomniac bidding on them! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif Carter 4070 on the way, and a Crane LX92 coil to go with the Crane Fireball electronic ignition! I think I might be compensating for too much snow...
jlaird
Yep, that works just fine.
blkcorvair
Hey Duncan, I was running a Napa elec pump. Fairly common square one with the same holley reglator you have. Back pressure shoulding hurt that mech pump though as it is simply a diapham it will only slow down flow. Now with the su i kept my mech pump and the regulator but also the napa 12v. The napa pump will actually pump through the mechanical pump. I use it only to "prime" the system when it sits too long. Block off plate though. Yep you got it. I have to tell you though, this single su makes my dgv look like a kindergardener. (HS4) Performs sooooooo much better. That weber just always required too much adjusting and maintenence. SU is dialing in 1 pin and keeping it topped with oil. A rebuilt su is the way to go.
tosoutherncars
tosoutherncars
Hi Scott,
Thanks for the info! Just for the sake of cleanliness, I think I'd rather pull the mech pump, but I know a lot of the guys with earlier cars run a cube inline with their stock pump, in case of failure! The belt & braces approach, as my grandfather would have said.
Why was your DGV dropping out of tune? Anything in particular? I'm hoping that, once it's all tuned up, it shouldn't be bad... certainly, anything is better than the craptacular CD150. And the bay looks much nicer without those hot water pipes running everywhere!
But yes, a nice set of SUs or similar would definitely be nice... I'm trying not to spend *too* much time modding the Midget, it's supposed to be my driving car! (summer, of course) The VW is my official 'project' car. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
M Fuel pump rating for Weber DGV Carb? Spridgets 6
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
B Weber DGV Spridgets 2
B Weber DGV Throttle Cable MG 2
bugedd weber DGV help Spridgets 6
sparkydave Weber DGV running at last! Spridgets 0
sparkydave Weber DGV and 1500 Spridgets 1
7 Weber 32/36 DGV with intake for sale or trade Triumph 1
7 Weber 32/36 DGV with intake for sale or trade Spridgets 0
X Weber 32/36 DGV fast idle rod MG 0
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv, selecting jets, air correctors? Spridgets 15
R weber 32/36 dgv parts? Spridgets 7
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
RickB Weber dgv for my Midget? Spridgets 14
R weber dgv 32/36 installation on 1500 midget? Spridgets 4
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
C MGB Weber DGV setup on 74 MGB MG 13
eejay56 Weber DGV or twin SU HS4s Triumph 12
B Done with this Weber DGV Spridgets 3
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
B Weber DGV troubles... Spridgets 3
J Weber DGV on a Bugeye Spridgets 5
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
B Do Not give up on the DGV Weber..... MG 12
1976Midget weber DGV Spridgets 10
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
sparkydave Weber DGV for a 1500? Spridgets 10
S weber dgv tuning help Spridgets 3
A Vacuum Lines and Weber DGV's Triumph 3
M Flat Spot on my Weber 32/36 DGV MG 3
R Spitfire Sooty Spitty 79 W/Weber DGV Triumph 4
I WEBER DGV Carbs? Triumph 2
R weber DGV's Triumph 5
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
