k&n air filter p/n for weber dgv on 1500 midget?
Midget78
I got my Weber conversion through Moss and requested an additional when I ordered the DGV kit. I dont think they actually have them listed in the catalogs to sell with a part number but if you call and ask for one they will should sell you one. Honestly, those air filters look like they can be cleaned up with some shop air an cleaner and put back on without actually replacing the entire unit. K&N make pretty good long lasting elements.
R
RonMacPherson
K&N also used to have a web site with a contact phone number....HTH
bighly
Midget78
Hey I have had my Weber conversion on for only a few weeks and have had it out only a few times. How do you like it? Are you happy with it or do you wish you picked some other carb for the car? So far mine seems ok yet it is still early to say.
R
recordsj
I bought the car with the weber already on it, so I don't have anything to compare it to.
I do see a it a little bit slow when getting going from stop. I do get about 34-37 mpg.
tosoutherncars
Mine's running great now, good power, since ditching the mechanical fuel pump, putting in a Carter low-pressure, and setting the carb correctly. Did a head rebuild and bumped the compression at the same time, so I can't comment on whether the power increase is solely due to the carb.
Midget78
I noticed it is a little slow off the line also but other then that it seems to run smooth as ever on the highway. I have the mechanical pump still being used but put an in-line fuel regulator with a gauge and have it dialed to about 3 1/2 lbs of pressure.
Stewart Oil for weber air filter MG 4
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
DrEntropy MGB Air filter MG 16
F TR4/4A Replacement air filter for SU HS6 Triumph 6
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
E MGB Oiling foam air filter MG 3
M Cooper's Air Filter on H1 Carbs Spridgets 5
tahoe healey Cooper decal on air filter Austin Healey 2
tahoe healey Original Air Filter Maintenance Austin Healey 4
D TR2/3/3A Air filter Triumph 11
sim air filter box for a DCOE 40 Spridgets 3
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
G Brake Booster Replacement Air Filter Austin Healey 4
G TR6 TR6 air filter element replacements for stock housing Triumph 3
Patrick67BJ8 Denis Welch Air Filter for BJ8 Austin Healey 22
J Air filter help Austin Healey 0
J AC air filter tricks and maintenance Other British Cars 0
fpstude TR4/4A Air Filter Soaked With Gasoline - TR4A Triumph 9
W Air Filter Removal Austin Healey 9
G TR2/3/3A paper air filter for tr3 Triumph 1
D MGB mgb air filter MG 2
davidb AH oiling the air filter Austin Healey 13
M Healey Air Filter Rebuilding Austin Healey 1
B SU Air Filter Mounting Triumph 6
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
W GT6 GT6 air filter Triumph 3
jjbunn Air filter cannister guests Jaguar 6
G Euro carb air filter clearance problems Spridgets 2
Newkie Air Filter Assembly question MG 23
F air filter over ram pipe Spridgets 1
P Air filter securing mod Austin Healey 11
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
N Brake servo air filter Austin Healey 2
D Spitfire Spitfire air filter element Triumph 7
T Air filter options Triumph 3
T Metal air filter assembly and/or HS1 carb set Spridgets 0
B Picture of Original Bugeye Air filter Spridgets 3
19_again oil and air filter upgrade options? Triumph 10
S E-Type Air Filter Breather Jaguar 0
tweety foam air filter Spridgets 1
C Su carb air filter Austin Healey 1
Brooklands Air Filter for Stromberg 175's Triumph 3
fmichaels air filter question Spridgets 6
eschneider MGB mgb stromberg re-jet for hi-flow air filter MG 30
Z Air Filter Oils Austin Healey 1
Baz K&N Air filter assbly Spridgets 5
Atrus Air in fuel filter Spridgets 11
Woodie air filter vendor Spridgets 2
Woodie air filter diameter Spridgets 0
