Air filter help
JSabah
I took my AC air filter (for the SU carbs)apart too have it powder coated as part of my SP 250 restoration project. That mention taking the wire mesh fabric out (as well as the spiked band that keeps it in place).
Now I find I cand get the mesh back in, but having great difficulty with the spiked band that keeps it pushed towards the outside....any tricks?
Also, I know that the mesh is supposed to be coated in oil in order to work. Is that done before re installation or after?
I realize many change out the air filter to foam or K&N, but this car is to be kept original and will only be driven 1 or 2,000/yr.
Thanks for any help.
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
DrEntropy MGB Air filter MG 16
F TR4/4A Replacement air filter for SU HS6 Triumph 6
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
E MGB Oiling foam air filter MG 3
M Cooper's Air Filter on H1 Carbs Spridgets 5
tahoe healey Cooper decal on air filter Austin Healey 2
tahoe healey Original Air Filter Maintenance Austin Healey 4
D TR2/3/3A Air filter Triumph 11
sim air filter box for a DCOE 40 Spridgets 3
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
G Brake Booster Replacement Air Filter Austin Healey 4
G TR6 TR6 air filter element replacements for stock housing Triumph 3
Patrick67BJ8 Denis Welch Air Filter for BJ8 Austin Healey 22
J AC air filter tricks and maintenance Other British Cars 0
fpstude TR4/4A Air Filter Soaked With Gasoline - TR4A Triumph 9
W Air Filter Removal Austin Healey 9
G TR2/3/3A paper air filter for tr3 Triumph 1
D MGB mgb air filter MG 2
davidb AH oiling the air filter Austin Healey 13
M Healey Air Filter Rebuilding Austin Healey 1
B SU Air Filter Mounting Triumph 6
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
W GT6 GT6 air filter Triumph 3
jjbunn Air filter cannister guests Jaguar 6
G Euro carb air filter clearance problems Spridgets 2
Newkie Air Filter Assembly question MG 23
F air filter over ram pipe Spridgets 1
P Air filter securing mod Austin Healey 11
N Brake servo air filter Austin Healey 2
D Spitfire Spitfire air filter element Triumph 7
T Air filter options Triumph 3
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
T Metal air filter assembly and/or HS1 carb set Spridgets 0
B Picture of Original Bugeye Air filter Spridgets 3
19_again oil and air filter upgrade options? Triumph 10
S E-Type Air Filter Breather Jaguar 0
tweety foam air filter Spridgets 1
C Su carb air filter Austin Healey 1
Brooklands Air Filter for Stromberg 175's Triumph 3
Stewart Oil for weber air filter MG 4
fmichaels air filter question Spridgets 6
eschneider MGB mgb stromberg re-jet for hi-flow air filter MG 30
Z Air Filter Oils Austin Healey 1
Baz K&N Air filter assbly Spridgets 5
Atrus Air in fuel filter Spridgets 11
Woodie air filter vendor Spridgets 2
