help...? Air Filter ideas needed...nothing fits!
Colin8
That a pretty tight fit for sure. What about a different intake manifold - perhaps there's something available that's shorter that would give you some room?
It looks like you are trying to use the heater air duct as a cold air supply. What about putting an air filter at the forward end of the duct? That would require the duct to be air tight for proper filtration, but perhaps making the carb box easier to fab?
Ok...I'm only "blue-skying" here...don't laugh too much...what if you had a small spacer made that would turn the carb 45 degrees towards the front - or maybe 60 or 90 degrees? that would give you a lot more space and options for filters, etc. I don't know how that would affect your performance, throttle linkage etc. Something to think about.......
jhorton3
Wow, that's a really tight spot to put an air cleaner! You might get away with a thin pancake filter, or something from K&N. You might want to consider putting some kind of padding or wrap on the roll bar right there. Reason being whatever you put in will probably bang up against it causing rattling and scuff marks.
bill_powell
DougXKindCoffee said:
I've been considering an air box of sorts that would enclose the roll bar
and the carb or maybe an inlet tube and a remote air filter...suggestions?
[image]https://viewmorepics.myspace.com/index.cf...mageID=64876182
An inlet tube is exactly what I would do. As an example:
You could also locate the air filter where it would receive a more 'ram-air' effect. I had this for a while on my Midget:
But went to a standard K&N (since I had the room) when I switched out the CV carb for an HIF6:
You may see that I now have the air inlet tube butting up against the K&N.
Just my thoughts~
Gundy
The K&N conical filter is pretty small and the conical shape helps with tight spots.
Here's mine on a HIF6 single carb.
dklawson
I was also going to suggest an elbow and inlet tube.
Bill... what's that "non-SU" carb in the center picture?
Doug, what needle are you running in that HS4? I know this is a bit of a thread hijack, but I've just fitted an HS4 to my Spit's 1300 and I know I need a different needle.
bill_powell
The PO installed that. It's a Keihin CV (constant velocity) from a Harley Davidson! It worked okay, but was difficult to tune and was <span style="font-style: italic">BLEEP</span> on a cold day. I kept it in place for a couple of months. Naw.
jvandyke
Re: help...? Air Filter ideas needed...nothing fi
At one point I had mocked up a cold air intake to go around behind the head, in front of the heaterbox, then join with the heater box duct, then have a K&N coin filter sticking into the hole beside the rad (where the stock line is) That was for a Weber carb and I had the carb "hood" for it. I then decided to go SU (the correct decision I think) and just stuck with stock intake bits.
You're already on the right side of the engine bay with an used duct, why not rig something to the firewall and put a K&N cone on it, draw in cool air through a bigger filter? Kinda like what you were thinking. Is there room for a boot on the carb with an angle on it to get pointed up and over toward the firewall?
Wow,
Quite a few nice ideas and many thanks for the pictures.
I like the idea of an inlet tube... even if THAT runs to an airbox/filter.
will also check on to check the dimensions of the conical filter.. it might fit.
Keep the ideas coming or pictures.. always happy to copy success :smile:
Again... thank you for the ideas
Gundy
Minimania.com lists the conical K&Ns and has sizes listed
for different carb applications.
The styrofoam idea sounds like the way to craft a box.
My main aim is for better/adequate filtering and not so musch the cold air.
I just have doubts that the current set up is filtering a whole lot.
nomad
I was in the small scale fiber glass business when a pup and if I remember correctly polyester resin melts styrofoam instantly. If you are going to make up a temp form for one off parts go with foamed urethane. You can shape it easily with a electric carving knife and surform rasp's. Saran wrap makes a decent parting barrier as well. Used to shape minor changes in mold's with modeling clay with poly vinyl alcohol sprayed over the clay. Leave's a coating exactly like saran wrap.
KA.
nomad
I should have qualified that post with the words "rigid foamed urethane". I used to get it from plastic's supplier. I would think that for one off's "home foam" thoroughly cured would work.
KA.
Colin8
White, expanded bead Polystyrene foam (EPS) or styrofoam does dissolve readily with polyester resin. For one-off designs, you can use this foam, but the fiberglassing must be done with epoxy resin, which does not attack the foam. After the part is built, poor gasoline, laquer thinner, acetone or similar solvent into the mold and dissolve away the foam. I've seen many one-off motorcycle gas tanks made this way. It's handy since you don't have to worry about release films or draft angles.
As others said, with polyurethane foam you can use polyester resin since it doesn't attack the foam. You do need release film and draft angles in order to remove the mold without destroying it. This method is best if you want to make more than one since the mold is reusable.
nomad
Good to know Colin. I have'nt been around this stuff in quite a while. Is epoxy resin easy to come by for a hobbiest now days?
KA.
Colin8
I usually use West Systems epoxy and buy it from West Marine since they have a local store. There's no relationship between the two companies, only the name is similar. 'W'ood 'E'poxy 'S'aturation 'T'echnique was developed by a couple boat builders who decided to market materials. It's good quality epoxy, but there are many other sources too. Local hobby shops for small quantities or Aircraft Spruce & Specialty Company is another online source for West and other high grade epoxies.
Epoxy is always stronger, has better adhesion and less warpage than polyester resin. But it's more expensive, cures slower and more difficult to sand. Polyester resin and glass fibers aka 'fiberglass' is typically used for cars, boats or other products where strength and weight are less important than cost. Epoxy and glass or carbon fibers are more often used for aircraft or other products where strength and weight are more important that cost.
The fact that expoxy doesn't dissolve polystyrene foam is an advantage for one-off construction.
nomad
Gonna have to look into making up a epoxy carbon fiber laminate!!
KA.
jlaird
They were the Geogon brothers, or something like that, use to race sail boats with them.
J Air filter help Austin Healey 0
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
55modified need help with custom air deflector for BN1 Austin Healey 12
TomMull Air compressor help needed Restoration & Tools 2
Jim_Gruber A little Thanksgiving Help - Bugsy is now up in the air Spridgets 14
G help with a part Id. cooper air cleaner? Other British Cars 1
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
GBRandy Wedge TR8 [or TR7] Fresh Air Intake Seal - help Triumph 8
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
justin_mercier Wedge TR7 Air conditioning help / books/ manuals? Triumph 16
H Air Deflector Assembly Hardware Help Request Austin Healey 2
Tinkerman Air Compressor Help Triumph 22
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
