KVH
I installed the “Viton“ split seal—rear main seal when rebuilding my TR4A engine. From a review of a great number of posts dating back 10 years, I can see folks having issues with the flywheel bolts interfering with the split seal. Despite following the instructions that came with the seal kit, some of us have experienced interference when installing the fly wheel and bolts.
Well, I just checked my flywheel while rebuilding, and I can see that the bolts are interfering slightly with the seal.
In reviewing prior posts, it appears that the use of washers is not recommended. Some form of hardened steel washer “might“ be OK, but it appears that the better solution is to shorten the bolts by about a 16th of an inch, perhaps as much as 1/8 of an inch. That’s the protrusion beyond the crankshaft.
Shorter bolts apparently are not available. I measured the new bolts that I ordered several months ago, and they are slightly longer than the ones that I removed from my flywheel. I am reluctant to use the old ones, and I believe it’s possible even the old ones will slightly interfere.
I’m just wondering if anyone has any violent objection to grinding these bolts a bit shorter as indicated. I see that it has been done in the past, apparently with the concurrence of others here.
Thanks for any advice.
