Flywheel removal
trotti
Bolts are off easily enough but I can't remove the flywheel itself. Any pointers? Not sure the BFH approach would be good on the crank?
The flywheel is probably stuck to the crank flange by surface corrosion. You can spray the joint with penetrating oil (including the bolt holes), let it sit for a while, then tap around the circumference of the flywheel with a wooden or rubber mallet. You don't have to hit it hard.
There wasn't any corrosion, but it was stuck on there pretty good. But I ended up doing was using a small pry and going back-and-forth from either side. Took a lot of back-and-forth but it eventually worked. Thanks!
I hope you know, but just in case, as I've mentioned in other posts, the flywheel has a #1 stamped on it. When you replace it, the #1 needs to be at the top when the engine (piston #1) is at top dead center. This is how it was balanced.
Yup! That was mentioned in another post and I kept the alignment straight. The flywheel is back on the car and I'm simply awaiting a complete set of matching bolts for the pressure plate - the PO used one bolt that was over a 1/4" shorter. Likely not a huge deal, but why introduce imbalance? The bolt store here in Nashville closed an hour early for some reason yesterday so I missed my window to get this in over the weekend. I'll have to do it this week.
Feels good to be at the "putting back together" stage. And I decided to purchase an engine lift - should make moving the gearbox around much simpler!
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
Y MGB Flywheel saga continues.... MG 24
Y MGB Flywheel resurface? MG 2
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
Michael Oritt 100 Flywheel Weight Austin Healey 16
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
WHT Denis Welch CENG635SO Flywheel Austin Healey 0
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
J BJ8 flywheel take some pounds off Austin Healey 17
roscoe Flywheel orientation question Austin Healey 3
R TR6 Pilot bushing clearance and Fidanza flywheel Triumph 0
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
M TR2/3/3A What Flywheel is this? Triumph 3
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R Wanted BJ8 FlyWheel Austin Healey Classifieds 6
M TR2/3/3A Starter and Flywheel Combinations Triumph 2
Rut Crank/flywheel dowels Spridgets 3
JimLaney Flywheel Pitting Spridgets 4
S TR2/3/3A Alloy flywheel Triumph 13
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
drooartz ID a 1275 flywheel Spridgets 2
D TR4/4A flywheel bolts maybe too long Triumph 15
drooartz Looking for a 1275 flywheel Spridgets 17
A 1955 100/4 Flywheel Info Austin Healey 4
T Post-War Other Herald flywheel Triumph 3
B Clutch disc - which side goes towards flywheel? Austin Healey 8
abarth69 1275 Flywheel Wanted Spridgets 7
CJD TR2/3/3A Clutch/Flywheel Bolts Triumph 28
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
J TR2/3/3A Flywheel bolts Triumph 1
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
DNK General Tech Flywheel Bolts Triumph 6
K TR6 Flywheel installed without the locating dowels? Triumph 5
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
O TR2/3/3A TR4 Flywheel Triumph 4
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
RedTR3 TR2/3/3A Moss [ARP] Flywheel Bolts Triumph 16
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
D Flywheel Ring-gear replacement Spridgets 18
B BJ7 Flywheel Help Austin Healey 11
DerekJ Lightened flywheel options Austin Healey 62
K Keeping a Flywheel from rusting.... Triumph 13
TR4A_IRS TR4/4A TR4 vs. TR4A flywheel question Triumph 19
F TR4/4A Lightened Flywheel for TR3A/TR4 engine Triumph 12
T WTB: flywheel MG 4
F Timing marks on the flywheel - 1100cc Spridgets 7
rjc157 lightened flywheel Austin Healey 9
