TR2/3/3A How many guide holes in TR3 flywheel for crank pin?
TuffTR250
I'm trying to determine if I mounted the flywheel correctly on my TR3, but at this point I don't want to remove the flywheel. If there is only one guide hole in the flywheel, then I may have it correct. If there are more than one guide hole, I may have it out of alignment to the way it was balanced. If anyone has a flywheel they can look at, please let me know how many guide holes for the crankshaft pin and where they are located in relation to the "arrow" mark on the edge of the flywheel. Thank you!!!!
Regards,
Bob
CJD
I just checked...the bad news is my early flywheel has 2 alignment holes that are 90 degrees out.
The good news, a good balancer will balance the crank, then add the flywheel and balance it. That means the flywheel position should not matter, as it is balanced after the crank is balanced. It is still best to keep them mated as balanced, but it should not make a difference...unless the balancer was in a hurry and just bolted everything together and balanced it all as a unit.
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
ahealey1004 For Sale MGB OD transmission, many parts in Phoenix,AZ MG Classifieds 4
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
M TR2/3/3A How many miles to seat piston rings? Triumph 4
M Fat Feet hitting too many pedals Austin Healey 23
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
Y MGB First of probably many questions - driveshaft transplanting: MG 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
NutmegCT So many cars! So much has changed! Other Cars 10
Tr3aguy General TR So many parts Triumph 7
AngliaGT Many Minis Spotted 5
Sarastro TR4/4A TR4 saga continues: why does Craigslist attract so many flakes? Triumph 16
T How many hours to reassemble a BE? Spridgets 16
Rut MGB Too many cars MG 31
M How Many McLaren owners are here? Other Cars 6
K Spitfire '78 cuts out after many miles of driving Triumph 8
S This is why I spend so many nights in the garage... Spridgets 7
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
J E brake help forgo many Big Healey owners Austin Healey 8
B How many of you have or had an Austin A40 Somerset Other British Cars 16
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
MikeAH100M How Many BN2 Overdrive Relays?? Austin Healey 2
J How many people retain their original generator? Spridgets 16
Frank C. How many Healeys are still on the road? Austin Healey 10
B TR6 Removal of TR6 crankshaft end bolt! MANY THANKS! Triumph 3
af3683 SU Carbs - How many flats? Triumph 3
JamesWilson How Many Left? Spotted 6
HerronScott How many left in the UK Triumph 6
03RedSRT4 Our Jensen Healey restore project, many questions. Other British Cars 35
JPSmit Too many cars too little time Other Cars 4
N craigslist post - many MG parts MG 1
T I'm an idiot / Hazards of too many projects / help Triumph 9
W How many carpet clips... Spridgets 8
richberman How many takers for collapsible steering? Austin Healey 12
S MGB-GT Too many MGB GTs.......? MG 3
drambuie How many more core's can a stock radiator handle Austin Healey 8
G 1500 Registry [how many here?] Spridgets 17
B How many ways can you say UGLY!!!! Spridgets 25
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
Newkie Trim moulding? How many clips? MG 5
Bremer TR2/3/3A How many ground straps on a TR3A? Triumph 4
M Many Questions thread Spridgets 21
