SU Carbs - How many flats?
af3683
I was wondering how many "flats" folks typically find they have to lower the mixture nut by on their TR3 SU H-6 carbs to get them to run properly. Also, am I correct that to lean out the carbs you need to <span style="text-decoration: underline">raise</span> the nut by turning it clockwise? Thank you.
Art
Geo Hahn
As viewed (or imagined) from above, turning the nut...
<span style="font-weight: bold">L</span>eft is <span style="font-weight: bold">L</span>eaner
<span style="font-weight: bold">R</span>ight is <span style="font-weight: bold">R</span>icher
Not sure on how far out -- maybe 2.5 turns?
af3683
af3683
Thank you. I was inclined to view it from the bottom looking up not looking down from the top. So basically if the nut was all the way up it would be fully lean and all the way down fully rich. This coincides with the TR3 service manual (Fuel System, p. 24) which says that the mixture is "weakened off by screwing up the jet adjusting nut" and "enriched by unscrewing the jet adjusting nut."
Thanks,
Art
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
steveg TR6 HD6 carbs on TR6? Triumph 16
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
sundown TR6 carbs Triumph 2
doc50 Su carbs for a Metropolitan? Other British Cars 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D BJ8 Carbs Overflowing Austin Healey 20
T TR2/3/3A Will 5W/20 oil work ok in carbs Triumph 4
R TR2/3/3A Rebuilding H4 carbs Triumph 8
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
Jim_Gruber Screws for HS-2 carbs Spridgets 5
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 Topping up cd175 Carbs Triumph 8
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
HighAltitudeTR3 TR2/3/3A SU H6 Carbs all out of whack!! Triumph 14
J Backfire through carbs Austin Healey 3
wangdango Colortune for HD8 Carbs? Austin Healey 55
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
