TR2/3/3A TR3B SU carbs
psutr3
Bought new H6 SU carbs for TR3B. After putting oil in chamber I noticed that the piston in one carb required much more pressure to raise and fell at a slower rate. When I reversed the dampers on the carbs the the rise-fall of the pistons reversed. I’m not the greatest mechanic but I understand that the pistons should require about the same pressure to rise and fall at about the same rate. First, is that correct? Second, can I correct it or should I contact Moss for another pair of dampers? I tried dampers from an old set of carbs and they actually seemed to give a more even rise-fall. Whatever help I can get is appreciated.
Gary
DavidApp
Sounds like a badly made part. One of the pistons is not right. Moss may supply new dampers. The New SUs are not a cheap item.
David
CJD
Before sending them back, perhaps remove the pistons and clean the pistons and domes with carb cleaner. See if that evens them out. I'm thinking there could be some preservative on them from the factory. If that doesn't help, then +1 on returning them.
sp53
How about when the engine is warm and the brass filler rods are removed, do they fall any better? Anyways heck yes 2K for the carbs--- be happy—send them back.
steve
charleyf
There is a large spring underneath the dome of each carb. Could one be missing? There are several things that determine the fall of the pistons besides the dampers. But in truth, if just cleaning them does not correct the situation you should send them back. If you just paid what I see they are selling for then you should get good products. If it were me I would not give them the option of only replacing the dampers. Replace the whole set.
Charley
poolboy
If the problem followed the damper...it's the damper...Sometimes the damper rod can be a tiny bit bent, just enough where there's some friction from rubbing the wall of the damper well..
sp53
If the needle is not centered they will not fall correctly either. They could need a good adjusting. I doubt if they can be sold adjusted. Mess around with your old set to understand the basics.
steve
poolboy
That's true, but didn't the problem follow the damper exchange ?
bobhustead
I recall reading from some seemingly authoritative source that the pistons and covers are sets and it is not always possible to swap a piston from one cover to another. Could you have made such a mix-up in handling the parts during assembly or installation? On rereading your first post, the swap of dampers reversing the problem may be inconsistent with this possibility
Bob
bobhustead
After a bit more thought, has the result of your damper swap not told us that the problem is one of the dampers, as Ken says?
Bob
P
psutr3
Contacted Moss and parts guy was very pleasant and helpful in explaining their policy and my options but could not do much. It was referred to tech people who could take as much as two weeks to call me. It does seem to me that it is the damper but the parts guy can’t do anything until tech people make a decision. I could buy two new dampers but that is another $90 plus shipping and I am not inclined to do that. I could buy another set of carbs and Moss would refund the cost of one set if tech people decide first set had a defect but if they don’t….. I’m just going to wait for tech people.
Gary
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
glemon TR2/3/3A TR3B Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
P TR3B Coil Issue? Triumph 7
P TR2/3/3A TR3B Panel Light Switch Triumph 20
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
J TR2/3/3A TR3b Tyres Triumph 6
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
W TR2/3/3A TR3B ‘TCF’ on BAT Triumph 10
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
K TR2/3/3A Windshield stanchions on a TR3b - guide plates?? Triumph 13
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
D TR2/3/3A TR3B Tire sizes? Triumph 10
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
J Restoring a '62 TR3B Restoration & Tools 2
M TR2/3/3A TR3B Door Cables Triumph 5
M Door Cables - 62 TR3B Spridgets 1
B TR2/3/3A Are these seat slides for a TR3B? how do you paint them? Triumph 8
B TR2/3/3A carpet snap questions tr3B Triumph 1
B TR2/3/3A TR3b lower door seal question Triumph 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
B TR2/3/3A steering box seal replacement TR3B Triumph 4
af3683 TR2/3/3A TR3B Exhaust Manifold Gaskets Triumph 15
C General TR TR3B Cylinder Head Triumph 7
af3683 TR2/3/3A TR3B Signal Flasher Problem? Triumph 2
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
B TR2/3/3A Identify the Mystery Bolts from TR3B front and interior Triumph 2
T TR2/3/3A TR3B fuel gauge Triumph 3
T TR2/3/3A TR3B stanchion to frame scew size Triumph 8
T TR2/3/3A TR3B alternator leak Triumph 4
T TR2/3/3A TR3B steering wheel cover Triumph 25
T TR2/3/3A TR3B VB windshield Triumph 11
M TR2/3/3A TR3B Front suspension Triumph 5
T TR2/3/3A TR3B gas cap Triumph 0
T TR2/3/3A TR3B steering column felt bushing Triumph 2
V TR2/3/3A TR3B Engine Oil Triumph 8
af3683 TR2/3/3A TR3B Rear Handbrake Cables Triumph 8
T TR2/3/3A TR3B horn wiring Triumph 4
