Sent my carbs out to be rebuilt (Apple Hydraulics). It ran prior to taking them off.
Put everything back together - made sure to check the jets were at correct levels and centered. Adjusted the idle screws per the manual. Am getting gas to the float bowls. Fuel pump is working. Taped the chokes to starting choke position (tried it open as well).
I get nothing unless I use starting fluid when trying to start. Starting fluid fires it right up, but won't stay running.
What else am I missing?
