Willie_P
I pulled my Tr4 engine from the chassis almost 10 years ago to the month. It has not ran since. I have stored it in the corner of a non-climate controlled garage in the Northeast through intense Summer humidity (think sweating cement floor) and sub-zero winter weather. the carb/intake and distributor were stored inside of my home. all holes/orifices on the engine were blocked-off appropriately.
the engine was rebuilt about a year prior to my removing it, as was the carbs and gearbox. (the body was not restored, which was the reason I did all of this in the first place). the car/engine was in complete running/driving order before I removed the engine and I'd been regularly driving the car with no mechanical issues.
I drained the engine of coolant, but kept motor oil in it. I regularly poured oil through the head and judiciously through the intake valves. 2x per year I would hand crank the engine a couple of revolutions using a big lever i would bolt to the fan hub extension.
the engine has been remounted, oil changed, new spark plugs gapped/installed, carb/intake remounted, coil, wires, starter, etc, etc, etc...all of that is ready to go.
I'm familiar with the general procedures for re-starting an engine, but are there any "special" tips like, using old spark plugs (instead of the new ones) in case it fouls, etc? I'd appreciate any help.
