Wedge Starting problems TR8
paddy.cox
Hi
I have a 1980 TR8. A few weeks ago I was driving the vehicle and all was good I’m in 4th gear at 60 mph when all of a sudden everything went dead. I lost power brakes, steering and propulsion, fortunately I was able to stop without causing a problem and ended up AAA back home !
The car had start issues and it was recommended to change the cold start which I did. I also had the cpu worked on at the wedge shop and re fitted that. I have a spark but not even a hint of starting !
I have never worked on fuel injectors (and don’t really want to) but it’s sorta pointing that way ??
Anybody have some ideas ? Thanks in advance
Paddy
Frank Canale
A couple of easy checks you can do your self, check to see if the fuel pump fuse is blown. next to check, turn the key on not to start and see if you hear the fuel pump whirring sound. There may be a fuel pump replay but that is a little harder to check. Frank
Darrell_Walker
You will need to open the flap in the air flow meter to allow the pump to run. Another easy way to verify fuel is to remove the cold start injector from the plenum, put it in a ziploc bag, and crank the engine. You should see fuel spray into the bag (assuming pressure, and the thermotime switch is working). You might invest in a fuel pressure gauge, as even if you have fuel, the pressure might be off.
Lots of other components on the system that can be tested individually, search for Bosch L-jettronic diagnosis, you won't find Rover V8 specific information, but the components all work the same.
H MGB Starting Problems MG 3
R Very Difficult cold weather starting problems! Austin Healey 21
M TR6 Intermittant starting problems Triumph 4
M MGB MGB starting problems. MG 9
bighealeysource Starting electrical problems ? Austin Healey 8
J Starting problems...... Triumph 5
ronzet Starting Problems MG 5
brendanf Starting Problems Jaguar XJ6 1982 Sovereign Jaguar 10
D Starting problems MG 11
R 80 MG starting problems MG 4
R MGB MGB engine starting problems MG 9
A Starting problems MG 2
A Starting problems MG 1
A Starting problems MG 4
dklawson Starting Problems: Lock - Lube & Solenoid ? Spridgets 2
Whytock Starting problems MG 1
F starting problems XJR Jaguar 3
F starting problems XJR Jaguar 1
D Starting Problems Spridgets 18
S 2000 XJ8 Starting Problems Jaguar 4
D Help Jag Mk2 hot engine starting problems Jaguar 4
J healey starting problems Austin Healey 5
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
