starting problems XJR
firefox
Hi , I have some starting problems with my Jaguar XJR -95 sometimes it start directly and some times not ??????
the engin runs but it will not be started, and i have no ignition on the sparkplugg???? Help ! firefox Sweden
Is this car a V-12?
If it is, and you have the Marelli type ignition, or similar, check the rear magnetic pick-up that counts the teeth on the flywheel.
The connector will be a two pin connector along the firewall, most likely on the l/h side. Check the connector for corrosion.
The front pickup is used more for after the engine runs. If the cable for the rear pick-up has come into contact with the exhaust, it will burn and short out. The engine will run, but it will not start.
Good luck
It´s a 6 cylinder 4.0 L with compressor, but I will try to check the magnetic pic-up to day and hope for the best.
Thanks !
Hallo Michael
I have found the front pickup and there was no problems with it so far so good.But I cant found the cable or the rear pick-up??
Can you help me
Best Regards
Lasse
F starting problems XJR Jaguar 1
H MGB Starting Problems MG 3
P Wedge Starting problems TR8 Triumph 3
R Very Difficult cold weather starting problems! Austin Healey 21
M TR6 Intermittant starting problems Triumph 4
M MGB MGB starting problems. MG 9
bighealeysource Starting electrical problems ? Austin Healey 8
J Starting problems...... Triumph 5
ronzet Starting Problems MG 5
brendanf Starting Problems Jaguar XJ6 1982 Sovereign Jaguar 10
D Starting problems MG 11
R 80 MG starting problems MG 4
R MGB MGB engine starting problems MG 9
A Starting problems MG 2
A Starting problems MG 1
A Starting problems MG 4
dklawson Starting Problems: Lock - Lube & Solenoid ? Spridgets 2
Whytock Starting problems MG 1
D Starting Problems Spridgets 18
S 2000 XJ8 Starting Problems Jaguar 4
D Help Jag Mk2 hot engine starting problems Jaguar 4
J healey starting problems Austin Healey 5
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
