TR2/3/3A I'm stuck... alternator/wiring/starting/?
flickerdown
Note: I did cross-post this to Triumph Experience as well but I'm out of ideas...
I'll add pictures later tonight.
2 things I did:
1.) Moss Alternator replacement for the generator
2.) Wizard Radiator/Fan combo
I've removed the fan electric from consideration right now to focus on the core problem.
first:
switched from positive to negative ground.
new positive terminal to starter solenoid lead. pretty easy swap. just flipped the battery around. have verified with a battery tester (Black and Decker charging) that the battery is at full charge.
second:
generator to alternator replacement. all good here and I DID NOT replace the generator wiring ends on the alternator side (moss provides a spade + plastic box kit)
third:
i followed the direction explicitly. I've removed the replacement lucas terminal and have the following wires:
green/blue, green/yellow, and yellow --> all connected to the same terminal post (easiest way to test connections)
original ground (black) is disconnected and now off to the side and not attached to anything
yellow/red (16/18awg?) is butt-connected back to the yellow lead.
Wiring.JPG is current state.
test wiring.JPG was using a press in connector for testing.
first test:
when i FIRST tried to test, the dash ignition light came on and the starter button worked. there was a SPARK from the positive terminal. engine did not turn over.
second test:
I forgot to change the leads over on the ignition coil so, I did that, made sure all the wiring connections were solid and...no light, nothing.
I'm stumped.
any ideas how to test? I do have a Fluke 80 that I can use to test wiring though, at this point, I'm really unsure as to what I'm going to be testing...I'm stumped.
HELP!!!!I'll add pictures later tonight.
2 things I did:
first:
second:
third:
first test:
second test:
I'm stumped.
HELP!!!!
TomMull
Did you switch the leads on the ammeter? I think that is polarity dependent.
Tom
TR3driver
Great Pumpkin - R.I.P
I think I read on TTE that you got this problem resolved.
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
richberman e-brake stuck on Austin Healey 36
Boggsy64 MGB Truly stuck now MG 10
T TR2/3/3A Stator tube, wires stuck Triumph 15
KVH The Shifter Again--and I'm Stuck Triumph 10
