TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear?
karls59tr
Bronze
I installed a new disk,plate and bearing...bolted up the trans....set up the slave adj....I got about three shifts in and the trans seems to be locked up?....can't move the shift lever. The cross shaft seems to be moving as it should when the pedal is pushed down.
I did remove the gearbox top cover when I had it on the bench.....I thought I might have misaligned the selector forks when I reinstalled the top cover but after removing it again the forks seem to be situated in the right place.
I must have done something wrong so I guess I'll have to pull the gearbox?....anyone have any ideas?
TR3driver
Great Pumpkin - R.I.P
With the engine stopped, you should pretty much always be able to shift back to neutral even without the clutch. So I doubt it is a clutch problem. Most likely (in my limited experience) a top cover problem, like maybe the shift interlock wasn't assembled properly or one of the shift cups has come loose on the shaft. I've seen a shift interlock that the owner swore has been working for years, but one of the balls was MIA and the pin in the middle eventually got turned sideways and jammed the center rail in 3rd gear.
mallard
I agree with Randall and check the top cover first. I've known others that had the same problem and it had to do with those balls.
thechileman
This is something I have occasionally on my TR4. If I lift up my shifter to go into reverse, and end up in fourth, or second, my shifter locks up. The only way to get it freed up is to take the shifter off, and move the selector forks with a screw driver. Once they start moving, I can reinstall the shifter, and everything works fine. I can do it in about 20 minutes now. Happens about twice a year to me. Not sure this will help your situation, but thought I would share.
K
karls59tr
Bronze
Aha! Now that you mention it there was an incident with the top cover.....I had a cluttered workbench and it got knocked over onto the floor......maybe I dislodged of the the balls that was mentioned.....would I be able to see if that was the case by looking? This is a TR6 gearbox....I have two spare TR3 top covers I could use. Are the 3top covers same as the 6????
I also have a TR4A top cover which might be the same as the 6???
TR3driver
Sorry I just saw this. There's no way to see the shift interlock, but you can test it with the lever out. Just use your fingers or a small pry bar to select each gear, then try to move each other rail into gear. Having any gear selected should lock the other two rails into neutral.
There are a lot of variations in top covers, even within TR6. But the castings will interchange as long as they have the switches you need. The forks and rails are different, though, so you'll have to swap them around.
I'm actually using an early TR3 top cover casting on my later TR6 gearbox (with TR4 overdrive), to keep the dipstick functional.
CJD
The interlock balls have no where to go, unless you removed a shaft. There is a chance it never had the interlock balls installed, from a PO's handywork, though.
My bet is that the tranny is in gear, but the cover was installed with the forks in the neutral position. The reverse gear fork is the most likely culprit. The solution is to use a screw driver to make sure the gears are all in neutral ( rear shaft spins freely), make sure the cover is in neutral (shifter wiggles across center easily), and then re-install the cover.
Are you sure you did not bend a fork when the cover dropped?
toysrrus TR4/4A Please Help! Send Pics of TR4 A-AM Radio Installed Triumph 16
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
