battery helmet stuck on post help
mk31755
My 6 volt batteries have seen there better days. I decided to change them. I can not for the life of me remove the battery helmets from the post. I have already destroyed one of the old batteries, after hours of cocking around. I've tried everything. They will not budge. I've tried the battery terminal lifter. That's all bent up now. I've tried prying, banging, lubricant etc What's a man to do? MK
The only thing you didn't mention is heat, but of course you'd have to be careful as the terminals are lead. Only thing I can think of is maybe drilling a small hole in the top of the helmet so you can get a penetrant--not lubricant--into the top of the terminal (I like Kroil, some like PBBlaster, etc.). Penetrants have ingredients to dissolve corrosion, which is probably your problem.
Besides leakage, I wouldn't worry about damaging the old batteries; they should still be good for cores
John Turney
Forget heat. I would worry more about hydrogen gas in the battery than the lead. The small hole in the top sounds like a good idea, but don't they have a screw there?
Michael Oritt
There should be a small screw in the center of each "helmet" holding it to the post. If so I would suggest removing the screw before getting too energetic,.
Keoke
mk said:
" I've tried prying, banging, lubricant etc What's a man to do? "
L TR2/3/3A helmet style battery terminals Triumph 7
Rob Glasgow Lucas Battery Cable Helmet Connectors Austin Healey 11
B Lucas lead 'helmet-type' battery cables Austin Healey 5
Team_Sprite Wanted: "Helmet" type battery cable ends. Spridgets 4
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
