Battery Lifespan
My Napa battery just died in 3 1/2 years. The previous Napa battery lasted 9 years. I use a float charger. Napa told me batteries now only last 3 to 5 years. Is this the new normal? Any recommendations other than Optima?
That's the 'new normal.' I had the same experience with Interstate, which used to be a go-to brand, in my 2008 Mustang. Mike Martinez, owner of Star Auto Electric, specializing in British car starter and generator told me 'All batteries are now made in Mexico' and, in so many words 'They're all crap.' One exception is Deka, made by East Penn manufacturing in Pennsylvania; I've had good luck with them (just bought a Napa brand supposedly made by them). East Penn makes batteries for a lot of different brands, including Napa, so it's disappointing if that battery was indeed made by East Penn. However, companies will source different batteries/brands for different price points, so all Napa batteries may not necessarily be from East Penn (like 'Napa Gold' oil filters are supposedly made by Wix, but aren't necessarily exactly the same as an equivalent Wix).
At any rate, for my BJ8, after having to do the 'baking soda flush' in the boot a couple times I sprung for an AGM (no leaks). It has 800CCA and spins the engine over quite rapidly (I'd rather spend $300 on an AGM than $300 for two cheaper, suspect batteries). I've got two Interstate 6V golf cart batteries in my BN2, and they've held up for a few years (but I don't drive it a lot and keep it on a Battery Minder).
NFI: > East Penn Manufacturing – The world's largest single site, family-owned lead-acid battery manufacturer <
equiprx
Been driving since 1965 in about 50 different cars and never had to buy a new battery.
I learned early to make sure the posts and connectors need to be clean and tight.
Top up with distilled water as needed and try not to operate accessories with motor off.
Guido36
I have had great results with Odyssey batteries - 10 years from the last one, but be sure to use a float/maintenance charger for AGM batteries.
tahoe healey
So, I got a new NAPA battery today. New warranty is now only 2 years. On the positive side (no pun intended) they had a $20.00 rebate. I have always used a maintenance charger. Napa said I need to drive more. But we get hard winters here.
... Napa said I need to drive more ...
Parts counter guys are now battery experts? Who'da thunk. I've done a bit of research and, if you believe their pitch, and I do, a 'smart' charger does a better job of maintaining a battery. A good smart charger uses a periodic higher frequency pulse to, supposedly, break-up lead sulfate deposits that form on the plates and settle to the bottom of the battery, which can eventually short out the plates. Yes, if you don't drive your car(s) often they can self-discharge and build sulphate deposits, but smart chargers both charge the battery, maintain a specific 'float charge' and run a desulphation cycle when appropriate. Funny, my dad's '46 Chevy 2-ton truck with a 6V system sits for months at a time, with no charger, and always answers the bell.
<Soap box mode: ON>
Batteries are like just about everything in our 'disposable' society: built to a price point to be just good enough so that return/replacement costs don't exceed profit margin. It's a good bet most production was moved to Mexico to cut labor costs and for Mexico's relatively lax environmental laws; lead and concentrated sulfuric acid are pretty nasty stuff (Mexico's starting to wise-up, apparently). Lead plates eventually erode, and it's my observation battery construction has been cheapened overall; I've had quite a few 'leakers' that weren't all my fault (overfilling, bad regulator). That's probably why warranty periods have gotten shorter.
<Soap box mode: OFF>
Keoke
I have had no troubles out of
my Delco sealed units.--+
A Battery Minder. is always used when the car is in the garage..
twas_brillig
for the last sixty or so years, I've just assumed a five year battery life - either here with winters or down south with heat. Use a couple of different 'smart' chargers to keep the batteries functioning in the vehicles that aren't being driven. And I can't afford to shop at Walmart (yes, this is a simplification): I want value, not 'cheap'.
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
RAC68 Battery Powerline Protection Austin Healey 40
Patrick67BJ8 Battery Tenders Austin Healey 36
