OK to paint battery?
Stan Kowznofski
Yes, if the paint is even the least little bit conductive (even if it is imperceptible with an ohm meter) it could lead to an inexplicable drain on the battery. It's the same reason you never leave a battery sitting on a concrete floor. It may also void any type of warranty. If it matters that much get a battery box.
LarryK
Moss sells a period correct cover. The concrete floor was for the rubber batteries as the condensation on the rubber conducted a ground. The battery manufacturers say that doesn't happen today, but my battery charging table is wood.
GeorgeC
GeorgeC
Member
Larry,
I've looked at Moss online and their catalog, can't find a cover. Do you have a part number?
Thanks
LarryK
No, saw it in a catalog, might call them, as I threw all my old mags out.
Sarastro
Frankly, if that's what you want to do, I don't see a problem. My greatest concern that the paint might not adhere well, would start to flake, and look pretty awful. I've yet to see a paint that is sufficiently conductive to load a battery; even metal-filled paints and adhesives are sometimes surprisingly nonconductive. In my opinion, the old idea that putting a battery on a concrete floor discharges it is just not correct, and the explanations for it are largely ad hoc. I suspect the apparent discharge is really just a poorly charged battery sitting on a cold floor, which reduces its output, or some similar phenomenon. But when someone shows me some real data proving that the phenomenon occurs (and I don't mean anecdotal experience) I'll change my opinion.
LarryK
Good point. In the early 70s, my boat batteries wers stored on 2x6s on the basement floor and charged occasionally.
Madflyer
I think the only time a battery would sit on concrete and not be on a board or such thing would be on the way out. and only lead acid type. As for color I would go with it as in a cover . My car is green so I got an Interstate battery and latter got a dry cell. Madflyer
Sarastro
Hmm. Mine sat on the concrete garage floor for about four years while I restored my TR4A. I put it on the charger occasionally to make sure it stayed fully charged--very important to prevent sulfation. It's back in the car and working fine now. I've done a load test on it, and I can't see any sign of deterioration. (It was only about 3 years old when I started the restoration).
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
P TR2/3/3A Chassis paint questions Triumph 8
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
D BT7 top/paint protection Austin Healey 5
