Oil release valve plunger stuck
Michael Oritt
Further to my post of a few days ago about low oil pressure I pulled the bottom end apart and will be replacing rod and main bearings. I removed the oil release valve cap nut and spring but cannot get the valve itself--the plunger--out. I had a small magnet probe that seemed to go all the way into the plunger's recess but it would not extract the part.
Is there some trick here? I had it out a number of years ago and do not remember encountering any problem. I could probably pass a tap into it from the side and engage the inside of the plunger so I could extract it but there must be some better way. Suggestions/experience appreciated.
gonzo
Dave Russell described using a dowel to fit the inside diameter of the plunger to properly seat it after lapping. Perhaps the dowel-technique could work to help extract the plunger. I like your alternate tapping method as well. Maybe a strategically placed blast 60 psi compressed air - with catcher's mitt? That'll get it. GONZO
Michael Oritt
Michael Oritt
Gonzo--
Thanks for the input. The top end of the engine is still together so I suppose if I put on an oil filter and blow air into the oil line running from the oil pump to the block that will exert pressure against the plunger.
I think Dave's suggestion of a wooden dowel is better than my idea of a tap--no metal shards! I often think of Dave--his knowledge was encyclopedic and his approach very no-nonsense.
dklawson
On A-series engines it is not uncommon to use a tap to extract the plunger. Find a tap that will just barely catch the inside diameter of the plunger. Get the tap started then pull it out with the plunger attached.
roscoe
A large fluted EZ Out would do the same. Since they are tapered it might not fit into the bore far enough before it it too fat.
CraigC
The ID of an original plunger is .500". If you can't get it to budge with the dowel method, a 1/4" NPT tap will just start to engage and grip the end of the plunger.
The problem with EZ-outs__misnomer of a name if there ever was one__is that by driving them in, outward pressure one the piece to be removed (be it a bolt/stud fragment or valve plunger) is increased against the bore that it's stuck in. Just the opposite of what you need.
I like the dowel method, and would've mentioned it myself if Gonzo hadn't beaten me to it. The wood will compress into the plunger long before it can influence the outside diameter. The dowel is most useful when seating a new plunger with a spot of fine valve-grinding paste to the existing seat. Use up the better amount of a can of brake-parts or carb cleaner to flush it out afterwards.
So what did the shells look like, or did I miss that post?
PS: I miss Dave too; encyclopedic knowledge indeed!
Michael Oritt
Michael Oritt
I am going to try compressed air up through the hole where the oil pipe goes into the block and if no luck will proceed to the dowel. More news as it develops.
The shells look very good.
Michael Oritt
Michael Oritt
A 1/2"-13 bottom tap would not get started but I found a 1/2"-13 taper tap that sufficiently engaged the inside of the plunger and allowed me to pull it out. The plunger looks okay.
I was able to find online specifications for the release valve spring for six-cylinder cars at austin-healey.com (A=2.7 litre cars and B=3.0 cars):
Release valve spring length:
A 2.562 (65.09 mm)
B 2.687 (68.26 mm)
Number of coils:
A and B 13
Diameter:
A and B .484 +.000 -.015
(12.30 mm +.000 mm -.318 mm)
but nothing for 100's and since there is an oil return passageway on the 6's that is not on the 4's I don't consider those dimensions relevant. My spring measured 2-15/16" long with 18 coils so it is a different animal altogether. It will be interesting to see if there is a noticeable difference in spring pressure between this one and its replacement.
I'm still working on getting the bottom end apart--the front and rear main caps are not being cooperative but I am patient.
K Spin on oil filters.....internal release valve? Triumph 5
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
