TR2/3/3A High beams seem to be stuck on when the headlights are turned on?
karls59tr
Bronze
Pressing the floor button to lower the high beams dosn't work. Is it a failure of the switch itself or is there a procedure to track down a wiring problem?
Sarastro
Had it been working previously? did you do anything with the wiring?
If the answers are yes and no, respectively, it pretty much has to be the dip switch.
Theron High Beams Spridgets 6
B High beams MG 5
kyreb1862 No High Beams MG 4
mrv8q TR2/3/3A TR3 High beams Triumph 2
D High Beams Triumph 6
Whytock High Beams MG 1
J High Beams MG 3
Carlbanan56 MGB High beam problems MG 4
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
D TR2/3/3A Alternator dial runs high Triumph 5
steveg High quality hose clamps Austin Healey 3
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
W Tachometer reads high when engine compartment heats up Austin Healey 3
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
4tecdog Misfire at high revs Austin Healey 21
warwick-steve Steering high spot - midway Austin Healey 17
warwick-steve High compression head identification Austin Healey 16
J TR4/4A High Water marks? Triumph 5
John Turney Another High-Priced "100" Austin Healey 11
D High beam Lamp Spridgets 3
D 69 E Type High Idle Jaguar 9
