High-Torque Starter
miraclemike
My BJ7 high torque starter was working then stopped. It makes a a noise like its hitting the flywheel but won't engage. Took it out and bench tested it, replaced solenoid and tested battery. Everything seems fine, but for some reason I hear the starter make sounds like its just hitting metal and not engaging. No spinning sounds either. Puzzled Mike
BobHaskell
Did you try rotating the flywheel a bit by putting the car in gear and pushing it?
bob hughes
Same thing happened to my BJ7 so I bought another pre engaged starter and that did not solve the problem. Then I went back to the battery connections, cleaned them up and now the starter works great. I am now the proud possessor of two pre engaged starter motors along with the original one. Give it a try you never know.
:cheers:
Bob
M
miraclemike
I tried that and got the same results. I've loosened the bolts to see if there was a little different seating position, but didn't feel any change.
I've tried just to leave the bolts a little loose without success. I'm going to try shimming but not too sure which bolt or how much.
Bill Young
Is the jumper still connected to the internal solenoid?
bob hughes
You may have a short or dry joint in the electrics some where. The starter takes a big load and if there is a short then it will shudder. Turn your lights on then try the starter, if the lights dim the you have a problem in the power line
Bob
gonzo
Check that Jumper Wire, and all connectors to the starter for corrosion. The jumper wire that included with the high torque starter I purchased was corroded and the copper wire was green. A fresh jumper was installed and the starter worked perfectly.
mezy
Just bridge the two 13mm nuts on the solenoid, if the starter does not spin up then its toasted,
the solenoid does two things it spins the starter and throws the the gear into the ring gear on the flywheel ,
if it just clunks with no spin then its only throwing out the gear not spinning the starter.
Martinld123
Bronze
I had similar problem with high torque starter on my 1956 BN2. Mine would engage but made a loud squealing sound first. I pulled out the starter and found the bearing was loose so I replaced starter to fix. I found I had just a small amount of side play but that was enough to cause noise. This may not be your problem. Just a thought. If you decide to replace I would not recommend the one from Moss Motors. Good luck, Marty
P TR2/3/3A British High Torque starter Triumph 6
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
B High Torque Starter Spridgets 7
T High Torque Starter Triumph 9
R New High Torque Starter Issues Triumph 5
B High Torque Starter Broken mount Austin Healey 1
E Bugey Starter Switch with High Torque Starter Spridgets 3
bill_powell High Torque Starter & Datsun 5-Speed Spridgets 3
T TR6 Best source for a TR6 high torque starter? Triumph 12
N high torque starter??? Spridgets 11
R High Torque Starter Austin Healey 2
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
DerekJ High Torque Gear Reduction Starters Austin Healey 2
Carlbanan56 MGB High beam problems MG 4
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
D TR2/3/3A Alternator dial runs high Triumph 5
steveg High quality hose clamps Austin Healey 3
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
W Tachometer reads high when engine compartment heats up Austin Healey 3
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
4tecdog Misfire at high revs Austin Healey 21
warwick-steve Steering high spot - midway Austin Healey 17
warwick-steve High compression head identification Austin Healey 16
J TR4/4A High Water marks? Triumph 5
