Spitfire '78 cuts out after many miles of driving
KeyMan90
I have a '78 Spitfire that we tore down and built back up over the past several months. The car is all together now and runs, but the engine will start shutting down after anywhere from 5 to 40 miles of driving. When it has died but is still moving, the accelerator pedal has no effect. If I push and release the clutch, say in 3rd gear, the RPM obviously drops to zero, but then comes right back and I have about 2-3 seconds of power. It has the original Lucas 45DE distributor upgraded with the Pertronix Ignitor ignition system, as well as proper coil, new wires, cap, rotor, and plugs. Timing is at 10 degrees before TDC. Carb is the original ZS 150CD that has been professionally rebuilt. Fuel system is clean and flowing a regulated steady 2-3 PSI. Voltage to coil remains steady. My personal thought is the Pertronix unit is heating up and cutting out (as electronics do not like heat), but I wanted to see what this community thought about my problem. Any help is appreciated!
pdplot
I had a Crane electronic ignition that cut out in hot weather. I sent it back to the factory and they said it was fine. I re-installed it and it continued to cut out. That was about 10 years ago. I've been running points ever since with no problems. I know zip about Pertronix. Others here can give you answers about that.
K
KeyMan90
I certainly agree with you on the points route as I ordered a new set for the other distributor I have that uses them to give it a try with the appropriate coil/resistor setup. Sometimes old technology is better I think!
Rhodyspit75
Try opening the gas cap when it happens. If the vapor recovery system is blocked the tank can't get any air to replace the gas that has been drawn off. It's pretty common on spitfires.
Elva164
Is it a sharp cut or a more gradual dying? If it's sharp, I would lean towards something electrical (the Petronix in particular). If it's more gradual, it's probably fuel related (like the situation Rhody suggested). I'd try swapping points and a condenser in and seeing what happens.
dklawson
As others suggested above, a slow drop in power and speed would probably be fuel related (including trapped tank vacuum as Rhodyspit suggested). If it is a sudden or rapid onset, ignition is more likely.
You said you have the "proper coil". What do you mean by that and how is it wired?
According to the wiring diagram linked below, the '78 Spitfire has a ballast ignition wiring system.
https://www.triumphspitfire.com/images/wiring/78diagram.jpg
If you have retained the original ballast coil wiring and connected the Pertronix "red" wire to coil (+) the module will not be running on full voltage. Pertronix modules do not like running on reduced voltage. The common workaround is to connect the module's red wire to a switched 12V supply.
K
KeyMan90
Finally figured it out! Switched to points distributor, no difference. Still acted like ignition. After much frustration, we tore the carb apart and found two pieces of debris right atop the float needle. Cleaned that out and ran like a champ!
I had originally wired the car with straight 12v to the Pertronix system, which as we know now, was apparently working fine. After all this, tonight I switched to the points system with ballast resistor, 6v coil, and the 4th 12v boost wire from the solenoid for starting. The points are working great so I'm going to leave them in. I'd like to thank everybody for their input on this issue! Many thanks!!
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
J Overdrive Cuts Out when... Austin Healey 11
J Overdrive Cuts Out when... Austin Healey 2
RAC68 Cuts in BJ8 Convertible Top Austin Healey 5
RAC68 Repair Traditional Cuts in BJ8 Convertible Top Austin Healey 18
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
Boink When one carb cuts out... Spridgets 8
T Making straight cuts & smooth edges for patches Triumph 5
B MGB MGB Cuts out, Tach goes dead..... MG 18
H Engine cuts out Austin Healey 9
R XJS CUTS OUT Jaguar 17
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
ahealey1004 For Sale MGB OD transmission, many parts in Phoenix,AZ MG Classifieds 4
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
M TR2/3/3A How many miles to seat piston rings? Triumph 4
M Fat Feet hitting too many pedals Austin Healey 23
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
Y MGB First of probably many questions - driveshaft transplanting: MG 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
NutmegCT So many cars! So much has changed! Other Cars 10
Tr3aguy General TR So many parts Triumph 7
AngliaGT Many Minis Spotted 5
Sarastro TR4/4A TR4 saga continues: why does Craigslist attract so many flakes? Triumph 16
T How many hours to reassemble a BE? Spridgets 16
Rut MGB Too many cars MG 31
M How Many McLaren owners are here? Other Cars 6
S This is why I spend so many nights in the garage... Spridgets 7
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
J E brake help forgo many Big Healey owners Austin Healey 8
B How many of you have or had an Austin A40 Somerset Other British Cars 16
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
MikeAH100M How Many BN2 Overdrive Relays?? Austin Healey 2
J How many people retain their original generator? Spridgets 16
Frank C. How many Healeys are still on the road? Austin Healey 10
B TR6 Removal of TR6 crankshaft end bolt! MANY THANKS! Triumph 3
af3683 SU Carbs - How many flats? Triumph 3
JamesWilson How Many Left? Spotted 6
HerronScott How many left in the UK Triumph 6
03RedSRT4 Our Jensen Healey restore project, many questions. Other British Cars 35
JPSmit Too many cars too little time Other Cars 4
