TR6 Removal of TR6 crankshaft end bolt! MANY THANKS!
bunzil
Thanks for your help everyone. While I've been wrenching for over 30 yrs I never considered upgrading to an impact wrench. Lordy be, the TR crank bolt just spun off - right now - with a simple $29 1/2 drive from Harbor Freight. I've had compressors for years...why didn't I get an impact wrench sooner.
Thanks again - the beauty of the internet and these forums.
bgbassplyr
HF also has a 3/8 "palm impact" that I use and like a lot. It's small enough to get into those 'tight' places. Not enough power to get that crank bolt loose, but it will twist the head off a 3/8 bolt.
Ask me how I know........on second thought, don't ask.
Platinum
:lol:
Jim, you're a brute. :jester:
Adrio
There are so (far too) many tool (and other things) that I have said the same thing about.
B TR6 Help with removal of TR6 crankshaft end bolt! Triumph 11
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
TR3TR6 TR6 Tr6 windshield glass removal Triumph 6
Scot1966 TR6 TR6 Head Removal Problems Triumph 30
TR3TR6 TR6 TR6 headrest removal Triumph 3
I TR6 TR6 fender removal help please Triumph 10
G TR6 TR6 dash and windshield frame removal Triumph 13
J TR6 tr6 timing cover removal Triumph 3
I TR6 TR6 Vent lid removal Triumph 6
I TR6 TR6 heater removal help please. Triumph 5
G TR6 TR6 innner door release and window crank removal Triumph 5
M TR6 TR6 Trunnion Bolt Removal Triumph 3
I TR6 help with TR6 windshield wiper arm removal Triumph 6
V TR6 TR6 Crank pully bolt removal Triumph 8
F TR6 TR6 Oil Folter Removal Triumph 10
Airfix TR6 TR6 Body Removal Triumph 6
R TR6 Late TR6 Front Fender Removal Triumph 5
Brian_Lekas TR6 TR6 Tranny removal Triumph 19
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
I TR6 TR6 rear axle u-joint removal help Triumph 14
dhungerf TR6 Body Removal Question [TR6] Triumph 9
E TR6 TR6 Timing cover removal Triumph 10
mrv8q TR6 TR6 half-shaft removal Triumph 15
B TR6 TR6 bumper removal - advice? Triumph 5
mrv8q TR6 TR6 gas tank removal Triumph 13
S TR6 74 tr6 rear bumper removal Triumph 27
SCguy TR6 TR6 trailing Arms bushing removal? Triumph 11
2wrench TR6 Help with horn removal '74 TR6 Triumph 6
S TR6 TR6 rear spring removal Triumph 11
J TR6 stuck again - ignition switch removal on a tr6 Triumph 14
I TR6 TR6 trip counter cable removal Triumph 4
C TR6 Starter removal help. 73 TR6 Triumph 1
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
J TR6 Stuck again. TR6 axel removal Triumph 11
T TR6 TR6 distributor removal - tips on tach drive Cable Triumph 5
roofman TR6 1972 Tr6 ignition switch removal questions Triumph 5
WidespreadPanic TR6 TR6 Steering Wheel Removal Success Latest w/pic Triumph 26
jerrybny TR6 73 TR6 Emissions Removal Triumph 6
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
G TR6 [TR6] removal of front transmission seal Triumph 5
ez_pa_6 TR6 TR6 windscreen assembly removal Triumph 5
E TR6 Windscreen removal Restoration & Tools 2
E TR6 73 TR6 windscreen removal Triumph 8
Slider748 TR6 TR6 transmission removal problem Triumph 12
C TR6 TR6 Body removal. Triumph 6
71tr TR6 TR6 body removal Triumph 13
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
