TR6 TR6 dash and windshield frame removal
G
So, I gotta pull the windshield frame to get the dash out? What I gotta unbolt and where?
DNK
Billy, you talking the dash front or the top??
trrdster2000
Kelly, after getting the ones at the bottom of the windshield on the inside, there will be two one at each end, under the dash, 9/16 inch wrench, a really deep well socket would be nice. The bracket these two bolts set in can be adjusted to get the door window to line up., if you don't have to loosen them up, leave well enough alone. Work the frame back and forth and it should come out. Lots of WD 40 or what ever you use.
Wayne
Tim Tucker
Removing
1. Remove the veneered fascia 76.46.01
2: Remove the five nuts and washer securing the metal
fascia to the crash pad.
3. Remove the two demister ducts 80.15.03.
4. Remove the windscreen frame 76.81.02.
5. Remove the crash pad.
Refitting
6. Apply S758 adhesive to mating surfaces of the crash
pad and the bulkhead panel.
7. Reverse instructions 1 to 5.
We'll get you more details. The wife says out to dinner for me. Good Luck.
Tim
G
That should be good enough guys. Don, the top pad.
I'm "while I'm ating it"
G
Man, what a pain! Got the passenger side to break free but driver's is stuck good. Soaked it down w/ PB and letting it sit overnight.
Stinger
Ours was pretty well stuck too and the only way we were able to remove it was with two people pulling together at the same time.
Brosky
And coat the pegs and their threads with Anti-Seize when you re-install it.
G
So I lossen the outter bolt closet to me in the fender too right? it's not that i can't get it to pull out, I can't get it to break free. You can see the D.S is still wedged completely in the mount. P.S is free and I can pull it up . D.S just won't budge. It'll wiggle, but not inside the mount. I have the dash face and wheel off so I can see pretty good up in there. I've even been hitting it w/ the heat gun.
Hoppy_H
Is the removal of windshield and dash pad replacement close to the same on a TR4.
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Thickness of original TR6 dash Triumph 2
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
rjc157 For Sale 74 tr6 dash Triumph Classifieds 2
S TR6 TR6 Dash refinish: a nice surprise Triumph 4
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
J TR6 TR6 Dash knobs Triumph 2
JimTR4 TR6 TR6 dash support in a TR4? Triumph 23
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
Tr4dude TR6 Tr6 resto dash Latest Triumph 3
V TR6 TR6 Center Dash Support Triumph 16
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
S TR6 TR6 Dash Triumph 18
G TR6 Dash support options for TR6 Triumph 8
Brosky TR6 Free dash panel, late TR6 Triumph 4
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
G TR6 TR6 dash lights not bright enough Triumph 22
mrv8q TR6 In the dash, '74 TR6 Triumph 2
I TR6 Veneer sanding, TR6 dash Triumph 3
C TR6 TR6 Dash Support Triumph 5
M TR6 TR6 dash Triumph 13
hondo402000 TR6 Veneering a TR6 dash Triumph 15
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
I TR6 TR6 dash help Triumph 8
I TR6 TR6 Dash help Triumph 7
I TR6 Reveneering TR6 Dash Triumph 3
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
B TR6 Installing a new dash in TR6 Triumph 38
2wrench TR6 How do I remove the rheostat from dash of TR6? Triumph 23
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
roofman TR6 72 TR6 dash lite reostat question Triumph 10
F TR6 Looking for TR6 metal dash support Triumph 4
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
I TR6 TR6 dash refinishing Triumph 7
J TR6 TR6 DASH HELP? Triumph 6
G TR6 tr6 - really dumb dash question Triumph 4
nathandarby67 TR6 TR6 Dash on ebay Triumph 0
Hawk813 TR6 TR6 Brakes Triumph 2
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
