1500 Registry [how many here?]
G
How many 1500 RB cars do we have here? Gotta pic? This include folks like Rick with "alternative" drivetrains. What do you have and how is it set up? Even if you've never singed up before, please sign in and let us know what you have.
RickB
de-bumpered
Mk1 grilled
datsun powered
halogen lighted
part green
mostly poop brown
soon with dogleg 5 speed back where it belongs
zip down rear window
hardtop for winter driving
1978 Midget
G
Saw Duplicolor green in quarts today at Pep Boys and thought of you.
JPSmit
Ms Triss, 1976 Midget, new bumpers, sidelights removed, reverse lights removed (and replaced) various other mods.
bigjones
Bronze
Pretty much stock except for:
Single HS4
Pertronix ignition
$9 Rustoleum Hunter Green (applied with a roller!) Hey - looks better than it did!
Currently undergoing a Kellysguy carpet restoration - already spent $8 plus tax. Temporarily on hold while I save up another $8 - also we are in the middle of a 3 day monsoon here in NC.
Cheers!
PS. Kellysguy - I like that subdued shade of red.
JP - looks like my poor rusty 1275:
G
$8???? Don't put the cheap stuff in, you'll hate it and it doesn't last. It was in mine from the P.O. Get good auto carpet from a carpet store.
Morris
Roll Bar
Bullet mirrors
Miata Seats (With headrest speakers)
Tube shocks on all 4 corners
Rebuilt (kinda) engine and transmission.
Computer controlled fuel injection and ignition
Delco alternator
Electric fan (computer controlled)
And roll up windows.
In dire need of a new paint job and head light trim rings.
RickB
Which green?
The only one I can find is the emerald green metallic.
bthompson
Stock engine except for Weber DGV, Pertronix, and 1275 dizzy.
Originally zesty exciting citron, now various tired faded shades of red, waiting patiently for a Rustolum repaint and new top install.
De-bumpered.
Complete SEM vinyl repaint in camel tan.
(Removed radio console due to psychological scarring.)
Lowe's cheapo carpet job. (not $8, but close)
G
bigjones said:
bthompson said:
...1275 dizzy...
That's interesting - how did you manage that, Bill?
All Lucas/BMC 4 cylinder dists are interchangeble. MGB will go on a MGA...will go on an A series or 1500 and vice versa. Very VW like as far as interchangibility. ( also looks allot like a bug Bosch dist.)
bigjones
Bronze
Um, OK, but what about the advance curve and what not? Wouldn't it be different if the engine size was bigger?
Cheers!
G
I mean physicallly of course. I'm sure they each have different advance curves.
bthompson
Yup. It's what was on it when I bought it. (The Lucas electronic probably gave way years ago and the PO went for a cheap fix.) The vacuum advance is kaput, and when I took it apart to check that the weights were free, they weren't standard for a 1275. I forget the specifics, but if the weights and springs were messed with, it was prob because the PO was playing with the curve for a 1500.
It runs, and doesn't ping with the advance set to 32 degrees at 3000 rpm. It's a little sluggish below 2K, which I'm sure is an advance issue. For now, it's good enough for me. One day I'll get around to it.
G
Fix the advance and it'll help out allot. ( dual Su's will as well)
I might have an advance that will fit, post me a pic.
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
