TR2/3/3A How many ground straps on a TR3A?
Bremer
Hi folks, just wondering what is actually grounded with a ground strap.
I know about the chassis to engine strap by the LH motor mount that connects to the front engine plate. But how does the chassis get ground? Is there a body to chassis ground strap? If not, would it be a good idea to add one?
What else needs to be grounded separately? I remember a post about the steering column having a strap (but that might have been for a TR4, pardon my ignorance).
Thanks!
tomgt6
I don't know a thing about TRs but I would say
<span style="font-weight: bold">When in doubt ground it out. </span>
OK I had to say it. It goes with my, When in doubt throw it out mentallity, when it comes to my wifes stuff.
TR3driver
Great Pumpkin - R.I.P
There is no separate strap between body & frame AFAIK; only the several bolts that hold the body to the frame. But they seem to be adequate; I didn't notice any change in cranking speed even when I ran a battery cable directly to the engine block.
No strap needed for the steering column on a TR2-3B. However, there should be a ground harness to the speedo and tach head (for the lights); and I advocate adding grounds for the fuel gauge, fuel tank sender, and all of the lamps in the rear.
Oh yeah, there should also be a ground wire for the wiper motor. It's used only by the park switch, but it's still a good thing to have.
Bremer
Bremer
Thanks everyone, this confirms that my LBC is not missing any straps. Depending on how it behaves during start-up I might add more grounding cables.
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
ahealey1004 For Sale MGB OD transmission, many parts in Phoenix,AZ MG Classifieds 4
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
M TR2/3/3A How many miles to seat piston rings? Triumph 4
M Fat Feet hitting too many pedals Austin Healey 23
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
Y MGB First of probably many questions - driveshaft transplanting: MG 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
NutmegCT So many cars! So much has changed! Other Cars 10
Tr3aguy General TR So many parts Triumph 7
AngliaGT Many Minis Spotted 5
Sarastro TR4/4A TR4 saga continues: why does Craigslist attract so many flakes? Triumph 16
T How many hours to reassemble a BE? Spridgets 16
Rut MGB Too many cars MG 31
M How Many McLaren owners are here? Other Cars 6
K Spitfire '78 cuts out after many miles of driving Triumph 8
S This is why I spend so many nights in the garage... Spridgets 7
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
J E brake help forgo many Big Healey owners Austin Healey 8
B How many of you have or had an Austin A40 Somerset Other British Cars 16
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
MikeAH100M How Many BN2 Overdrive Relays?? Austin Healey 2
J How many people retain their original generator? Spridgets 16
Frank C. How many Healeys are still on the road? Austin Healey 10
B TR6 Removal of TR6 crankshaft end bolt! MANY THANKS! Triumph 3
af3683 SU Carbs - How many flats? Triumph 3
JamesWilson How Many Left? Spotted 6
HerronScott How many left in the UK Triumph 6
03RedSRT4 Our Jensen Healey restore project, many questions. Other British Cars 35
JPSmit Too many cars too little time Other Cars 4
N craigslist post - many MG parts MG 1
T I'm an idiot / Hazards of too many projects / help Triumph 9
W How many carpet clips... Spridgets 8
richberman How many takers for collapsible steering? Austin Healey 12
S MGB-GT Too many MGB GTs.......? MG 3
drambuie How many more core's can a stock radiator handle Austin Healey 8
G 1500 Registry [how many here?] Spridgets 17
B How many ways can you say UGLY!!!! Spridgets 25
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
Newkie Trim moulding? How many clips? MG 5
M Many Questions thread Spridgets 21
