I'm an idiot / Hazards of too many projects / help
tdskip
Ha! Yes, I had this coming but work with me here.
Trying to help a friend with a Doretti project, so found him a flywheel and was going to help him with a proper starter. No worries, I have one that will be fine. Oh, wait. Is that for the MGA that is in bits or the TR3?
My brain is telling me that these units are the same but that could just be the jet lag talking.
Yes, I will label better in the future (which I am usually very good about actually).
Geo Hahn
tdskip said:
Have a picture by chance of the correct starter?
Here is a typical pre-TS50K 'bullnose' starter, I think the Doretti would use this type:
M_Pied_Lourd
Just thinking out loud....does it matter what flywheel Tom bought regarding the type of starter? Not sure but I think I recall that the started engages the flywheel differently from the early to later starter?
Cheers,
M. Pied Lourd
T
tdskip
Tush! How are you man?
Yes, starter is different I think. Not my stuff, trying to help friend out restoring a Doretti.
Geo Hahn
Both the flywheel and the bellhousing are different for the early bullnose starter. IIRC the early flywheel is press-on and the bellhousing lacks the bulge needed by the later starter.
Later bellhousing would work with early starter. For that matter, I have driven for 30 years with the late flywheel and the early starter but that isn't recommended.
matttnz General Tech Steering Wheel-Idiot question Triumph 5
AngliaGT IDIOT! - I need a L/H Midgett MKIII Hub Spridgets 10
B 1500 Alternator Idiot Light Spridgets 18
livinginthepast Okay, so I'm an idiot thread - Hardtop removal Spridgets 15
RickB uh-oh... what's it mean when the yellow idiot,,, Spridgets 18
B Have I been a idiot? MG 15
RickB Red idiot light on bright - ideas? Spridgets 33
amcboy Idiot test sat... Triumph 10
roofman Idiot Ebay scammer Triumph 1
G Timing - I feel like an idiot even asking Triumph 7
GB1 New MINI idiot lights British Motor Corp 5
J I'm an idiot..... Never assume. MG 3
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
philman The Hazards of a bad ground Triumph 4
R6MGS TR6 TR6 hazards...again....diff problem thou Triumph 3
B Sign of the times. Road hazards are changing. Austin Healey 2
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
M Fat Feet hitting too many pedals Austin Healey 23
DrEntropy MGB Differential with too much lash MG 5
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
S TR2/3/3A New shocks too short? Triumph 7
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
HalLucy Post-War Other Renown - Idle too fast Triumph 5
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
J TR4/4A Too hot to drive a convertible Triumph 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull TR2/3/3A New Top Too Tight Triumph 14
K Too lean? Austin Healey 2
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
warwick-steve How low is too low? [spring question] Austin Healey 19
Marla TR4/4A Carbs too lean? Triumph 11
D TR4/4A flywheel bolts maybe too long Triumph 15
kennypinkerton MGB Are my wheels too far gone? MG 8
