Clutch disc - which side goes towards flywheel?
blueskies
This is on the early 100-6. The car came with a new clutch disc and pressure plate, with no brand name marked on the parts. The clutch disc has no markings indicating which side goes towards the flywheel.
One side of the clutch disc has the center spline section protrude about one inch from the disc surface. The center spline area on the other side is more flush with the clutch disc.
Any help appreciated.
trrdster2000
The protruding side goes toward the transmission. The other way will make a **** of a noise for a one time shift.
Wayne
B
blueskies
Thank you. That's the way I installed it, to the rear, towards the pressure plate. Just to be clear, the protruding section I'm talking about is the center splined section, about 1/4 inch larger than the transmission output shaft. It may protrude 3/4 inch or 1 inch more than on the other side.
I started second guessing this when reading other posts, including for Triumph cars, where the protruding center should go towards the flywheel. Apparently even the factory manual is wrong on this point for Triumphs. So since Austin Healeys and Triumphs are somewhat related, I started wondering. It would be a lot easier to reverse the clutch disc before the engine and transmission go into the car than later on.
steveg
With the disc installed incorrectly, would you even be able to bolt the pressure plate up to the flywheel?
B
blueskies
Not sure, as I just tried it the one way that seemed right. The internet is full of stories about people who installed the clutch backwards. They often don't notice problems until they try to shift with the engine running.
Admittedly, this seems like a dumb question, but it would not be the first time I had to do something twice. The last two clutches I did were on my Kubota tractor (after the clutch/flywheel housing broke - the Kubota thought it was a D8), and on the Chevelle SS. It always helps with reassembly when one also took things apart. In this case, the 100-6 came in many pieces.
Keoke
-----------------YES-See what Wayne said :excitement:
steveg
I see what Wayne said; not sure he actually did it the wrong way on a Healey, or if he is surmising that is what would happen. From the previous comment it would seem the Triumph setup wouldn't be exactly relevant to the Healey.
If I recall correctly, with the clutch disc incorrectly oriented, its surface would not be able to seat against the flywheel, due to hitting the pilot bearing, and I would guess it would feel pretty strange when one was bolting the pressure plate in place, if indeed the bolts were long enough.
Keoke
P.S.
Steve____I DID---:glee:
Healeys and MGBs are the same, in that the protruding sprung hub faces the pressure plate (as blueskies installed his), but the other cars I work on the most, the '98-'02 BMW M Coupes/Rdstrs, theirs are installed the opposite way (and instead of a sprung hub, The Germans engineered a twin-mass flywheel__ever the ones to provide the most complicated and expensive alternative to a condition...).
Here's thread about a recent BMW clutch installation gone wrong (in the Philipines), just in case you needed anything to support your choice in British cars AND doing the work yourself ;)
https://www.bimmerforums.com/forum/showthread.php?2180468-Z3M-Roadster-Clutch-Replacement-Gone-Wrong
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
M TR6 New clutch disc needed Triumph 2
K TR2/3/3A 3A Clutch Disc and 4A Cutch Disc? Triumph 3
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
J Smitty clutch disc Austin Healey 13
T Luk clutch disc Triumph 1
SMGoose Wrong Clutch Disc? Triumph 2
K Saving a clutch disc.....old school method? Triumph 11
bugedd Clutch disc anyone? Spridgets 0
RomanH Sachs Clutch Disc Failure Triumph 12
K TR4/4A Can I fit a TR3 clutch plate&disc in a 4A? Triumph 4
K Method of breaking stuck clutch disc free? Triumph 10
germanmichel Fly wheel -gear ring and clutch disc questions Austin Healey 13
KLUTZ T-Series Acceptable clutch disc thickness? MG 4
Stewart T-Series Which way does the clutch disc face? MG 4
J Reuse clutch disc? Austin Healey 4
A TR6 Clutch Disc---which way?? tr6 Triumph 12
G TR6 How thick should a clutch disc be? [TR6] Triumph 2
MGTF1250Dave TR2/3/3A TR3 CLUTCH FRICTION DISC REPLACEMENT Triumph 9
Lutz Kramer Clutch is disengaging slowly Austin Healey 14
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
