rear brake drum too tight after rebuild
ah60_68
Hi all, I have spent some time looking for information on my problem. I used the Moss rear brake kit to rebuild the rear brakes on my 60 bt7. Drums were machined at a local shop. Right drum went on and turned with the ebrake connected. Left drum went on and turned until I reconnected the ebrake at the wheel. This connection was tight enough to activate the brake so that I could not turn the drum by hand. All adjusters are completely backed out. Cannot think of why one side would be fine and the other too tight. Can I simply adjust the ebrake to put some slack in the system? It may be a day or two before I get back to check on this so please bear with me. Thanks.
Deleted member 19315
The e brake or handbrake should not activate the rear brakes until the handbrake lever is pulled. Sounds like your cable is too tight.I r can be adjusted at the clevis pin connection to the rod system . This assumes you have set and centred the rear shoes clearance correctly with the adjuster in the backplate.
Andy
D Rear Brake Drum Nuts Austin Healey 15
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets stuck rear brake drum Austin Healey 18
K TR2/3/3A Rear brake drum won't go on? Triumph 12
glemon General TR Rear Drum Brake Adjustment Triumph 2
J TR2/3/3A Rear drum brake noise, Why?? Triumph 4
nevets Questions about rear brake drum removal Austin Healey 24
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
B Hot rear brake drum Austin Healey 9
tri_carb_healey rear drum brake problem Austin Healey 6
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
SCguy Wedge TR8 rear brake drum removal Triumph 28
I TR6 Rear brake drum temperature TR6 Triumph 13
I screws on rear brake drum area Spridgets 10
Thomas591 Rear Drum Brake Rubber Dust Cover Austin Healey 2
M Rear brake drum paint Austin Healey 7
Lin rear brake drum adjusters Spridgets 0
KVH General TR Rear Brake Shoe Orientation Triumph 12
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
R TR6 Rear brake wheel cylinder fitment Triumph 5
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G Rear Brake Adjustment Austin Healey 30
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
A AH 3000 rear disc brake conversion Austin Healey 28
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
warwick-steve Rear Brake cylinder connection Austin Healey 12
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
nevets BN6 rear brake pipes Austin Healey 15
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
C Help diagnosing rear brake issues... Austin Healey 20
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
SASSAMON TR2/3/3A Rear Brake Cylinder Recommendations Triumph 2
Jim_Gruber BE Rear Brake Spring Orientation Spridgets 13
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M suggestions on vendor Rear brake rebuild Spridgets 15
