MG Midget Early and Later model rear brake shoes....
Jim_Gruber
Backing plates changed with disc brakes. Single adjustment screw adjusts front and rear shoes. 1 wheel cylinder. Front disc came available 64 or 65. Superior braking. I used a 3/4” MC along with 3/4” wheel cylinders. Key is the grab rear backing plates as well as eBrake rods and balance from donor car and everything bolts right up with great pedal feel and brake balance. If you opt to keep Bugeye rear brakes a switch to Morris Minor 3/4” wheel cylinders helps balance braking and pedal pressure. I had my MC refitted with 3/4” Brass bushings that do not rust. Gerard Did my work but not sure if Not sure if anyone else resleeving in Brass anymore.
Bayless
I have had several sets of cylinders brass sleeved by http://whitepost.com White Post Restorations. They do an excellent job, including a lifetime warranty. I have never had one fail. My first time was about 30 years ago.
Gearhead Early dash in a later Midget Spridgets 3
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
AngliaGT Early '74 Midget - MC/Pedal Box Replacing Spridgets 3
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
AngliaGT I Need An Early '74 Midget Buddy Spridgets 5
AngliaGT Early '74 Midget Water Pump Bolts/Alternator Bracket? Spridgets 1
J Fiberglass Fenders for Early Midget MK1 Spridgets 11
Trevor Jessie Decent buy in the Mid-Atlantic on early Midget Spridgets 11
RickB Early Midget boot picture needed Spridgets 3
tony barnhill Early Midget Parts Car - Who's Got One? Spridgets 3
U Early '70's Midget Brake System Question Spridgets 5
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
