TR6 Rear brake wheel cylinder fitment
Ribbs
I'm replacing most of the components associated with the rear brakes and wondering about the rubber boot/dust cover that is located on the inboard side of the back plate and slides over the hand brake lever. After sliding it over the hand brake lever is it supposed to be located under the spring clips? I've got it there now but wow - that really makes for a tight fit on the retaining clips, and I'm concerned about whether the wheel cylinder will be able to have any movement to center itself and move when the hand brake is activated.
2002S2000
Good Evening. I just finished a similar project albeit on a 1960 TR3A which seems very similar to the TR6 rear brakes. The rubber dust cover fit fairly easily over the handbrake lever and then slid under the "clip" which had adequate margin/offset for this when the clips are installed in the correct order (which is a puzzle). After 2 test drives the brakes are functioning well (both hydraulic and hand brake).
R
Ribbs
Thanks for the reply and confirmation. I'll give it a try next summer when I hope to have everything put back together. It just seemed awfully tight such that the wheel cylinder wasn't free to reposition itself. I did get the backplate powder coated, which adds some thickness, which could explain some of it. Another one of those times I wish I had the Haynes manual to consult..
2002S2000
You're welcome........in case you are not aware, the cylinder needs proper lubrication where mounted both front and back side which enables the slight movement fore and aft (at least the TR3 does).
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
Stinger TR4/4A TR4A Rear Brake Wheel Cylinder Dust Shields Triumph 5
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
I Rear brake wheel cylinders Spridgets 1
KVH General TR Rear Brake Shoe Orientation Triumph 12
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
D Rear Brake Drum Nuts Austin Healey 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G Rear Brake Adjustment Austin Healey 30
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
A AH 3000 rear disc brake conversion Austin Healey 28
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
warwick-steve Rear Brake cylinder connection Austin Healey 12
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets BN6 rear brake pipes Austin Healey 15
nevets stuck rear brake drum Austin Healey 18
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
C Help diagnosing rear brake issues... Austin Healey 20
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
A rear brake drum too tight after rebuild Austin Healey 3
SASSAMON TR2/3/3A Rear Brake Cylinder Recommendations Triumph 2
Jim_Gruber BE Rear Brake Spring Orientation Spridgets 13
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M suggestions on vendor Rear brake rebuild Spridgets 15
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
K TR2/3/3A Rear brake drum won't go on? Triumph 12
RJS TR4/4A Rear Brake Hose Replacement Triumph 7
R Can't remove rear flexible brake hose Spridgets 5
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
C AH3000 MKIII - Rear Brake Problem Austin Healey 1
P Bugeye rear brake springs??????? Spridgets 5
CJD TR2/3/3A Early Rear Brake Cylinders Triumph 2
J TR2/3/3A Installation of rear brake cylinders for 9" brakes on TR 3A. Triumph 3
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
