I'm moving into my shop this Spring and have decided to leave my old 80 gal 3.5 horse single stage compressor in the old shop which is in the basement. My shop is totally non-commercial. While I've always been able to make this small compressor do, I've never really had enough air. Initially I'd thought of getting a 5hp two stage, which can be had for $1000 or so. If I read the specs correctly, that would improve my capacity by about 50%. Since I've been able to get by with my smaller one I could certainly get by with that.
However going to the next level, 7.5hp two stage will double my capacity at least. (It's hard to make a direct comparison because the capacity of the bigger commercial units is given at the compressors max of 175 lbs rather that the home units which are given at 45 and 90 psi.) Down side is that the cost is more than $2000. Budget is kinda stretched anyway but it would be really nice to worry not about running out of air. Also easier to keep water out of the paint as it would run cooler.
Any thoughts/ opinions will be appreciated.
Tom
Tom
