TR4/4A TR4 Starter and Solenoid Issue
KVH
I could use some help.
When I turn the key I hear that dreaded "click" (a single click), and nothing more. When that has happened in the past, I have always suspected the battery first.
However, in this case my battery was recently charged, shows 12.7 volts at rest, and a specific gravity test shows all cells alive and strong.
In addition, the car had been running great--until today when I had to push the car to start it. I get nothing but a click when I turn the key.
This evening, I got out and tried pushing the solenoid button in, and the result there was a bit startling.
Rather than a click this time, I got smoke, apparently from the solenoid, right where the wires connect, but the wires didn't seem all that warm. The solenoid housing was warm.
I tried pushing the manual solenoid starter button "in" again, and it stuck in the "in" position, but then finally popped back out.
My starter was rebuilt 3 years ago, and I have no reason to suspect that, but I just don't know.
So here's the question. Is it my solenoid or my starter. I doubt it was my battery. I also doubt it was my battery cables; those look clean.
Do I buy a new solenoid? Or, should I pull the starter and have it tested first?
The "click" sounded more like a starter click, but I dare not reconnect the solenoid after seeing smoke. I even wonder
if I may have blown anything by pushing in that solenoid button. I guess I'll see.
Thanks for the help.
My TR3A has a separate starter solenoid on the firewall. If yours is similar, disconnect the two heavy wires from the solenoid, joint them together with one of the cables from your set of battery starter cables and see if the starter turns over briskly. If it does, you need a new solenoid. Don't leave the clip from your starter cable connected too long or your starter will keep on turning.
Most of what you describe sounds like a classic case of dirty and/or corroded terminals -- those on either end of each battery cable (or possibly even the terminal clamps themselves where they attach to the cable), on the solenoid, on the starter and perhaps on the main ground cable from the engine. It's also possible that the solenoid has seen its last start, but it could have stuck temporarily due to getting a bit warm.
Possibly even easier than Don's suggestion is to get a medium sized screwdriver with a good insulated handle and use it to quickly bridge the two big terminals on the solenoid to see if the starter will then work.
Oh, and I seem to remember that the solenoids can be disassembled somewhat to clean them up...either that, or you might be able to use something like a WD-40 to clean and lubricate them. Not too much that can go wrong there.
I forgot to mention that the negative pole of my battery was also quite warm.
Should that make me think that my battery cable at that end actually was not clean and connecting properly, and that my problem is more simple than I thought? (it wouldn't be the first time I over-reacted to some symptom)
I already removed the solenoid and bench tested it. It seems fine.
Maybe I just need to clean the cables and put it all back together--and try again.
Andrew, yes, I'm suspecting what you say is the case. I'm going to clean everything, and put it all back together. I'm going to feel just a little silly if it fires right up.
One connection that you will not want to overlook is where the big cable connects to the starter. That spot (on my car anyway) can get hot and oily, not the best conditions for electrics. I have had it become a problem resulting in non-start, heat and smoke.
Maybe you have lost some of the Lucas smoke from the insides of your wires and/or cables. Check it and see if you might need to add some smoke to replace what you have lost.
I had the same problem with my MGB. My starter on the 65 MGB has two nuts on the post that connects the cable to the starter from the solenoid. I had tightened these nuts because they were loose. After I did this I had the same problem that you have and before the starter was working fine. I discovered that there is a fiber washer between the starter and the first nut that insulates the starter connection lead from the case of the starter. When I tightened the nut I broke this 45 year old fiber washer. I replaced the washer with two fiberglass ones I bought and presto I was back in business. My leads were also smoking because they were shorted out to the starter case.
Soundslike dirty connections to me. Remove the battery cables from the battery posts. Chean the insides where the cables get tightened to the posts. Clean the outside of both battery posts and reattach the cables tightly.
tdskip said:
Guys - what do we think the cause for this is? Is it the internals of the cables corroding?
It's possible, but more likely IMO it's poor contact between the clamp & post.
The currents involved here are huge (stock starter can draw over 500 amps), so it's easy to have a marginal connection that works fine except when trying to start the engine.
But I have even seen a battery break internally and get hot at the posts, so anything is possible.
Sorry if I wasn't clear, but I was asking if the cable to the battery might have internal corrosion that could be adding resistance and thus heat.
Ok, so just to be clear, I was saying that it is possible. However, in my experience, poor contact between the clamp and post is much more common, even if it looks clean and tight. So my first step would be to remove the clamp, clean both surfaces until they are bright and shiny (most FLAPS will have a brush for this for a couple of bucks), and make sure that the pinch bolt can actually pinch the post firmly. Add a smear of anti-corrosion grease (Vaseline), reassemble, and re-test. If it still gets hot, the cable might be at fault.
Or as someone else said, the starter might be shorted. I smoked the entire cable from battery to solenoid once, because one of the starter brush leads had gotten tangled in the commutator. It was cranking the engine, but really slowly, and apparently drawing several times as much current as normal.
Update TR4 Starter and Solenoid Issue
OK, I'm really at a loss.
I cleaned the cables, and checked everything. I tried to start the car.
WOW!
I got a big spark where the flat "eye ring" of the negative cable bolts into the body firewall of the car, right near the windshield. The cable connector at that location, on the firewall, actually exploded off the bolt. In other words, the ring connector at the end of the cable just exploded in half.
Calming myself down a bit (after checking whether I fried my entire wiring harness, I might conclude that the problem from the very beginning--when my car would not start--was the connection at the firewall.
Does this make any sense?
Do I dare put new cable on the negative terminal, bolt it to the body and fire it up?
I guess I should try it, since the only rational explanation appears to be a bad cable.
More info: Before all this happened two days ago, when my car first would not start, I had installed and removed my battery twice, so maybe it did weaken the ring connector on the cable and it was just ready to fall apart.
Thoughts? Thanks in advance.
Re: Update TR4 Starter and Solenoid Issue
KVH said:
I got a big spark where the flat "eye ring" of the negative cable bolts into the body firewall of the car, right near the windshield....Calming myself down a bit (after checking whether I fried my entire wiring harness, I might conclude that the problem from the very beginning--when my car would not start--was the connection at the firewall.
It does to me...that the cable, or at least that end of it, might have been bad all along.
Sure, so long as you've determined that there is no other damage as a result of your impromptu light show! :wink:
Makes sense to me, too. The heat at the battery post might have traveled the length of the cable, if you only felt at the post.
Not likely to be any hidden damage, so I'd just chase the threads, clean the post, and install the new cable.
I would suggest buying a new "external star" type lockwasher and putting it between the cable and the body. The points of the star will cut through the paint and help ensure a good contact at this point. Otherwise, you need to strip the paint off and expose bare metal to get a good connection.
KVH said:
...WOW! I got a big spark where the flat "eye ring" of the negative cable bolts into the body firewall of the car, right near the windshield. The cable connector at that location, on the firewall, actually exploded off the bolt...
This is why you should invite me over when you're doing this sort of stuff -- I really enjoy watching fireworks.
I scrape with an Xacto knife on the surface where the cable meets the firewall, not only removes any paint but presents a nice shiny clean contact. The star washer along with this should be good insurance.
Haven't looked real recently but last time I got a ground cable they were still carrying the braided type at the FLAPS, I think that looks more correct if such a thing matters:
I would also install a battery disconnect switch so you don't have to mess with the battery connections the next time you work on the car. Just use the disconnect and nothing gets pulled or damaged.
KVH TR4/4A TR4 Starter Triumph 11
Geo Hahn TR4/4A TR4 / late TR3A Starter Pinion Triumph 4
Geo Hahn TR4/4A TR4 Starter Rebuild Questions Triumph 13
M TR4/4A TR4 Starter Triumph 1
C TR4/4A New 1961 TR4 questions Triumph 2
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 22
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
