TR2/3/3A Hot day coolant overflow issue....
karls59tr
Bronze
Have owned the car for 20 years and never had an overheating problem till today. It is 30 celcius here. Gauge temp was OK when the car was running but when I shut it off awhile later I noticed a puddle under the rad. The leak was coming from the upper rad hose connection. I tightened up the screw clamp to stop the leak there. My question is why didn't the coolant come out of the overflow tube? Does this indicate a thermostat problem? I'm running a TR6 yellow fan,the rad is in good shape,the shroud is in good shape and I'm running water wetter. I have an electric fan mounted in front of the rad which I suppose I could have flipped on when I first came to a stop if I had thought I was running hot. Any thoughts?
charleyf
It does not sound like you have an overheating problem. You just had a loose connection problem. The radiator cap will hold pressure in the system to prevent coolant from exiting the overflow up to the poundage of the cap. A loose fitting will release coolant at any temperature.
Charley
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
F Hot Ignition Coil Austin Healey 6
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
T General Tech Running hot Triumph 8
KVH TR4/4A Hard Start When Engine Hot Triumph 20
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
D Lumpy Idle When Hot Austin Healey 2
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
7 General TR Hot rod Triumph 0
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
R General TR Emergency hot wire - because you never know whats next Triumph 2
F TR6 Pegged out hot while cold Triumph 7
sparkydave Trouble running hot Spridgets 10
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
T 1993 xj v12 red hot catalytic converter Jaguar 6
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
Bob_Spidell Running hot/Overheating Austin Healey 44
G TR4/4A Flasher Unit...VERY hot Triumph 10
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
pkmh How hot can it [temperature gauge] get? Austin Healey 4
dougie DD300 Runing Hot Austin Healey 6
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
glemon Hot Shot Other Cars 5
D Been waiting for a hot day run Austin Healey 4
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
J TR4/4A Too hot to drive a convertible Triumph 14
T Bj7 Overdrive slipping when hot Austin Healey 11
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
F TR2/3/3A Starts Cold, Not Hot Triumph 12
M TR2/3/3A Why is my coil so hot? Triumph 6
D TR4/4A how hot does the timimg chain cover get? Triumph 15
F TR6 sticky valve when hot Triumph 4
Lutz Kramer Hot cams and advanced ignition Austin Healey 57
HealeyRick Hot Volvo Other Cars 0
simpzimmer Spitfire Won't suck gas when hot. Triumph 7
steveg Healey hot weather driving observations Austin Healey 2
bugedd Hot legs and hood top bow Spridgets 15
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
N Jet Hot??? Spridgets 13
T TR2/3/3A Thermostats in Hot Summers and Moderate Winters Triumph 10
S Hot tip: seal for fuel tank sender Austin Healey 9
aeronca65t General TR Kastner Cup video walkthrough of hot pits Triumph 1
D Getting hot in the car [AH3000mk3] Austin Healey 6
