Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
When driving around town in hot weather in my 1959 TR3A the gear shift lever becomes so hot that I can hardly touch it. Should I be concerned about this? It shifts fine. Transmission is full.
Thanks,
TR3MT
I am not sure when it changed, but my 71 TR6 does not require lifting the lever for reverse. Just a sharp push to the right and back. Also, the proximity of the exhaust pipe to the trans. causes heat to be trans. and gear lever.
Berry
Berry
I disagree-my 1971 TR6 owners manual states that "to engage reverse, move the lever sharply to the right and rearward." The TR4 manual does state that lifting the lever is required to engage reverse.
Berry
John-I think we both might be right. This issue was kicked around on the Triumph Experience forum. It seems like the TR2-4 cars started out with a "ledge" on the shift rod that required lifting the lever to engage reverse, but with wear the ledge became a ramp. TR6s started must have started life with a ramp didn't require lifting and that is why the instructions in the owners manual changed.
Berry
And that brings up a possibility that the levers I have encountered that "seemed" worn, could have been TR6 replacements?!? AT this stage in our car's lives there has been a lot of repairs and swaps.
You don't need to be touching the shaft of the lever anyway, but yes, the transmissions do heat up.
In my MG race car I pulled in from practice once and immediately popped the tunnel out to check something. When I leaned over, a few drops of sweat dripped on the transmission case and promptly hissed and boiled away, indicating that the trans was at or above 212 F......
A rubber insert in a shift lever can add as an insulator but adds an element of flexibility that makes shifting feel just a tad odd.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
