TR2/3/3A Front brake rotors hot to the touch......
karls59tr
Bronze
I installed new wheel bearings and new brake pads. Would the new brake pads be just wearing in causing the rotors to heat up. If the car has not be excessively braked then parked should the rotors be that hot. Car seems to accelerate and coast OK but my concern is I may not have got the wheel bearing end play right. After my first test run I jacked up the front wheels and pulled on the the drivers side tire/wheel and found a fair bit of play there. I tightened the hub nut a bit and that took out the play in the wheel. I've read all the posts regarding the correct way to set the end play and I believe I set it up as stated. Can the end play be reset correctly with the calipers installed?? Can a dial gauge be used effectively to set end play with the calipers still on?
I had a severe front bearing failure last year at speed that really got my adrenaline pumping and I would not like to go thru that again. Any advice most appreciated.
NutmegCT
Just my two cents here, but - the pads are always in contact with the rotors. So heat will build up even if you don't use the brakes at all. Very different from drum and shoe brakes.
Is it only the pad/rotor that warms up? or also the brake and hub system?
Also, can you give us an idea of " ... should the rotors be that hot". You mean too hot to touch?
Tom M.
STeve 1958
Brakes work by dissipating kinetic energy in the form of heat, so any braking will heat the discs up. In racing they glow red but a few hundred degrees is normal, even for a quick run around the block. I don't know of any reason why you can't adjust the end play with the calipers installed.
TR3driver
Great Pumpkin - R.I.P
Make sure the pads are pushed back a bit, so they don't screw up the measurement. Having the dust seal in place also makes it more difficult to measure accurately.
Note that it may be necessary to sand down the washer just a bit, to get the specified clearance with new components. .003" to .005" (workshop manual has wrong numbers)
https://imgur.com/a/Uh6OA
Joe Schlosser
No the pads are not incontact with rotors when the brakes are not applied. The square caliper seal pulls the pad back just enough so that they are not touching.
If they are touching/dragging then something is wrong
TR3driver
On a TR3, there is actually a residual pressure valve that holds the pads in (light) contact, for at least some time after each application of the brakes. It does slowly leak down, but they will drag enough to notice (when turning the wheel by hand) when the valve is working properly. I actually remove the RPV on my cars, because I don't like that dragging feeling (even though in reality it does no harm to speak of).
More modern cars are indeed designed to pull the pads back; but for that to work, there must be some connection between the pads and pistons. TR3 disc brakes have no such connection. Even if the pistons somehow retracted all the way, the pads would still be out against the rotor, held there by the "damping" spring.
CJD
Yes...what Randall said! Warm to hot discs after driving is normal, since the valve does keep the pads in light contact with the rotors.
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
jsfbond Front Brake rotors Triumph 5
K TR2/3/3A TR-3A front brake rotors size Triumph 5
Basil Separating front brake rotors from hub? Jaguar 2
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
bighealeysource Front Brake Adjusters Austin Healey 0
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
I Bug eye front disc brake conversion. Spridgets 5
bighealeysource Question on 100M front brake cylinder Austin Healey 4
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
John Turney TR6 Brake Line to Front Calipers Triumph 4
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
I Wanted Sprite front brake parts Spridgets Classified 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
T Assistance with Front Brake Lines Spridgets 3
doc50 Met front brake pistons Other British Cars 4
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
AngliaGT Front Brake Dilemma - '74 cb Midget Spridgets 4
R TR2/3/3A Front Brake Conversion Triumph 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
G Rover P3 Brake Lining - Front Rover / Land Rover 2
K TR2/3/3A Front disc brake squeal.... Triumph 4
L Front Brake 100/6 Austin Healey 1
R Help with BJ7 front brake line routing Austin Healey 6
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
A TR6 '73 tr6 passenger front brake dragging Triumph 2
F Front brake hose BJ8 Austin Healey 4
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
F front brake hose 67 BJ8 Austin Healey 4
M Front steel brake lines Spridgets 9
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
R BJ7 Front Brake disc hitting Austin Healey 12
P Bugeye front drum brake picture Spridgets 7
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
bigjones Front brake job - any advice? Spridgets 94
RJS TR4/4A Replacing front brake hoses Triumph 10
C question on the front brake lines for BJ8 Austin Healey 2
nevets Front brake hose length Austin Healey 10
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
Top Bottom
