948 front brake shoes warning
certifiedcarnut
I just replaced my front brake shoes and wheel cylinders on my '62 Midget and couldn't get one of the drums on over the new shoes. Drove me crazy until I discovered the machining of the shoes was inconsistent. Some of the shoes contact points on the wheel cylinders are too high making the shoes sit too high so the drum can't clear the shoes. I had to file the metal contact points down on the shoes so they would sit low enough to cclear the drums. I informed Moss about the problem. All this time wasted and now I have the usual air in the lines which I am having the worst time ever getting out. Seems like I have spent most of the week on usually simple maintenance .
TulsaFred
I noticed extreme difficulty getting my front drums over the shoes as well. They still drag a bit. I'll check the contact points and get my file.
SaxMan
Good reason for an upgrade to front discs! :encouragement:
One of my winter projects is to service the brakes on my '69 Sprite IV...but we still have the autumn driving season to get through.
certifiedcarnut
certifiedcarnut
In reference to the inconsistent brake shoes I've been discussing. I received an email from Moss in answer to my concerns about the shoes, and I was told they don't have the staff to check on every part that comes in, and they rely on their "good customers" to help with this. I realize that they don't have the staffing to check everything, but how about a spot check of items from suppliers to see if samples checked are all the same size? I am still angry at the amount of time this wasted for me. Doesn't it get old wrestling with the brake springs over and over? Also I'm sure it was not good for my blood pressure. As Mr. Spock would probably say, " the fact that a brake drum that has always fit over every new brake shoe I have ever replaced, does not begin to go on over these new brake shoes is illogical."
bobhustead
I recently had a similar problem with new Moss shoes on the rear of my TR3. I chose to have the drums turned an extra pass. I've been working on cars for about 50 years and have had BUNCHES of non conforming parts from many retailers. Like Moss, they don't make the parts. Unlike Moss, some don't have a NQA return policy. If it weren't for Moss, et al., we couldn't drive these cars anymore.
Bob
certifiedcarnut
certifiedcarnut
I realize of course it is the suppliers. I have worked on my Midget for 51 years and this was the first time I ever had this experience with shoes I had to file down. Of all the dealers, Moss is the best, even if the late Frank Clairici always told me never to use them.
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
M 948 Pulley Nut Size Spridgets 1
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
B Reinstalling 948 engine Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
D 948 Oil Cap Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
D 948 clutch kit Spridgets 2
B 948 flywheels? Spridgets 8
6 Valve adjustment stock 948 Spridgets 11
longbridgehealey speedo cable 948 to 1275 Spridgets 2
I source for used 948 oil pan Spridgets 4
longbridgehealey another 1275 from 948 question Spridgets 3
longbridgehealey generator from 948 Bugeye Spridgets 2
B MG Motor - 948 parts or 1275 engine MG 1
7 948 sprite chewed the number three rod bearing MG 10
L Ribcase transmission with 948 engine Spridgets 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
I Bugeye 948 ignition timing help please Spridgets 8
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
Sarastro Improved clutch on a 948? Spridgets 7
I How do you static time a 948? Spridgets 4
I Head torque questions for 948 Spridgets 6
