948 Pulley Nut Size
mxp01
All:
Can someone tell me the size of the nut on the main pulley on the 948 engine? The largest socket I have is a 1 3/16ths but that is too small.
Thanks,
Mike Pennell
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
B Reinstalling 948 engine Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
D 948 Oil Cap Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
D 948 clutch kit Spridgets 2
B 948 flywheels? Spridgets 8
6 Valve adjustment stock 948 Spridgets 11
longbridgehealey speedo cable 948 to 1275 Spridgets 2
I source for used 948 oil pan Spridgets 4
longbridgehealey another 1275 from 948 question Spridgets 3
longbridgehealey generator from 948 Bugeye Spridgets 2
B MG Motor - 948 parts or 1275 engine MG 1
7 948 sprite chewed the number three rod bearing MG 10
L Ribcase transmission with 948 engine Spridgets 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
I Bugeye 948 ignition timing help please Spridgets 8
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
Sarastro Improved clutch on a 948? Spridgets 7
I How do you static time a 948? Spridgets 4
I Head torque questions for 948 Spridgets 6
