BJ7 Hard to find First Gear when G/Box is hot
Tassiedave
Gear selection works fine for first 30 minutes or so of driving then it becomes difficult to find first , second and sometimes reverse.
Have topped up gearbox with oil. Any suggestions as to why this has just started to happen.
Difficulty getting into first is common, almost ubiquitous, because it has no synchro. Standard advice is to 'kiss second;' i.e. start to go into second until it just starts to engage then shift into first. It's much easier to get into first if car is barely moving forward, so I creep up to stop signs if possible. Reverse is also often a bit harder to find, but difficulty getting into second while moving could be a worn synchro, as second gets shifted, and downshifted into probably more than any other gear and is most likely to wear its synchro ring. What brand/type oil are you using?
I almost always shift into neutral at stoplights for a couple reasons, mostly to reduce wear on the release (throwout) bearing, which have finite lives (though I've picked up the habit in my other manual gearbox cars). I usually use the 'kiss second' method to ease getting into first. What's really fun is getting into first when the car is rolling backwards.
PAUL161
Putting it in first when the car is rolling backward is not a good idea. Easy to chip a tooth. :driving:
Well, I assumed braking first. Got to be more explicit, I guess.
Getting into reverse quickly, when trying to back away from a lady in a FWD Volvo spinning her wheels as she tried to stop rolling backwards on Hyde St. in San Francisco--the backside approach to famous Lombard St.--can be an experience as well.
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
R winter hard starting BJ7 Austin Healey 16
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
A 1963 BJ7 - 6 months of hard work Austin Healey 12
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
JKent BJ7 clutch hard line Austin Healey 2
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
