Steering Arm Installation Recommendations - BJ7
gonzo
Any recommendations and/or best practices to follow when installing the steering arm onto the rocker shaft in the correct orientation? This is for a AH 3000 B7 that needed a new steering box so the steering arm is not indexed. Perhaps this would involve counting the number of rotations lock-to-lock then turn box half that number to center the rocker shaft. Thanks all.
G
gonzo
Agreed. I studied the rocker shaft more closely and figured it out Also used the # of rotations lock to lock to help locate straight ahead position. Thank you John.
C Steering Arm Castle Nut Torque Austin Healey 5
W Steering Arm Colors Spridgets 1
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
vette Steering Arm or Pitman Arm Austin Healey 6
G Steering idler arm removal Austin Healey 33
P Bugeye Steering Arm Bolts???? Spridgets 15
apbos Steering arm Tab Washers/ Lock Tab alternatives Spridgets 6
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
T TR2/3/3A tr3 steering box drop arm nut torque setting? Triumph 2
W Yet another yellow steering arm Spridgets 1
K TR2/3/3A TR3 Steering:Nut that attaches drop arm........... Triumph 2
W Steering arm lock washer Spridgets 3
MGBGT_noob MGB MGB Steering Arm Bolts MG 1
W Green steering arm Spridgets 2
J Steering arm colours Spridgets 8
A Steering box - Pitman arm removal method work? Austin Healey 10
bravenrace TR4 Steering Arm For 2500M? TVR 5
Trevor Jessie Steering arm question Spridgets 10
Monark192 Removing Tie Rod End From Steering Arm Spridgets 11
A How do I convince steering arm to come off idler? Austin Healey 10
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
