BJ7 Trim Recession (Convertible Top)
twas_brillig
The trim piece just to the right of the seatbelt (behind the seat, and exposing the screw head) has receded on both sides of the car, exposing the metal edge of the aluminum angled piece. And the dang corner has cut a slash in the tonneau cover. So, questions:
- what is the proper name for that trim piece?
- name for the wee rubber bit at the front of the trim piece?
- for the aluminum angle that it attaches to?
- what options do I have, other than replacing it?
I was thinking that I would go back about six inches from the end, cut through the trim, then slide the short piece forward (and anchor it somehow, if it won't stay). Put electrical tape or some such over the exposed aluminum edge. Any comments on this? suggestions as to cutting it (I figured tin-snips, but if anyone has tried other approaches, please advise). Etc.!
And has anyone else had this problem? It seems weird to me that the trim would shrink. Thanks, Doug
bob hughes
Doug
The trim may have shrunk due to someone stretching it on around the bend in the first place but as it a short piece, it does seam strange.
If I am reading this correctly, the trim piece is a part of a set Seal-Set hood /screen pillars according to that A. H. Spares catalogue,
the end cappings are just that, end cappings hood seal and they come in LH or RH. The Ally piece again is part of a set and is called RETAINER side and rear centre and comes as a set of 4 pieces.
I am sure that you could get the material on your side of the pond, , I would not have thought that you need new Ally, but If I was doing it I would get a new seal set rather than butt some pieces up, if you did go that route get some black adhesive/sealant and stick them to the ally and to each other. it will not look 100% but will help keep the weather out.
chicken BJ7 Chrome Trim Austin Healey 15
B BJ7 Boot Trim Austin Healey 7
D BJ7 Underdash Trim Austin Healey 9
D BJ7 Rear rail trim Austin Healey 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
B BJ7 Drain Channel and Small Waist Trim piece question Austin Healey 13
B BJ7 Chrome Door Waist Trim - Alignment help Austin Healey 8
maxwedge5281 1963 bj7 rear interior trim Austin Healey 45
chicken BJ7 Trim colour Austin Healey 1
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
T Early BJ7 Vent Window Seal Austin Healey 2
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
