BJ7 Clutch
  • Thread starter Deleted member 26655
  • Start date
BJ7 1963
The clutch works perfectly except when I'm coming off of the highway and off of overdrive the clutch pedal has little resistance and I cannot
get it into 3rd or second, it'll grind.
After double clutching a few times it works itself out but a bit annoying.
Any ideas appreciated.
Dave Walsh
red57
Pumping it a few times and it gets better suggests low on fluid or air in the hydraulic system somewhere. However, if it's air in the system or low on fluid, it should have the same problem all the time, not just coming off the highway.
Confirm if you start it up in the driveway and depress the clutch pedal just once, does it slip into gears easily? When starting out from a stop does the clutch start to engage at the normal pedal height?
If the pedal pressure was normal and hard to shift, it could be an oily clutch disc sticking to the flywheel or pressure plate. But since you say it's a soft pedal, and only soft when coming off the highway, it's a tough one - anything mechanical I can think of like something broken in the pressure plate, would be a problem all the time.
Had a similar problem with my BJ8's brakes once. Found the problem was a damaged 'foot valve' in the master cylinder; this is a small, spring-loaded seal that allows the reservoir to fill the master cyl., then gets closed when the pedal is depressed. But, like other possibilities mentioned this would happen on every application. I think only 'coming off of the highway' may be incidental. Bleed the clutch hydraulics then report back.
thanks
OK I'll try that, thanks Bob.
Have someone work the pedal while you watch the fluid in the reservoir, if it rises and falls with pedal application it's likely the foot valve
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
H Accessing clutch plate on Austin Healey 3000 BJ7 Austin Healey 5
JKent BJ7 clutch hard line Austin Healey 2
Sprocket BJ7 clutch slave sylinder question Austin Healey 5
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
