Rear shroud connection to the floor pan on a BJ7
bob hughes
Hi Guys
A bit of help required. I am in the process of fitting in a new floor to the boot (trunk) of my car as the existing one is somewhat wrecked - rust and filler in equal quantities.
I have looked around it and there appears to be holes at around 100mm,- 4 inch centers around the bottom of the shroud where it mates with the rear of the floor pan, though in my case, fixings have been fitted in only a few places, and I am not sure what they are.
Questions - I guess that there should be a fixing in every hole? when I get around to that part, and the next question is what to use, will pop rivets do and should they be the countersunk ones? or what.
:cheers:
Bob
The holes are for regular rivets, but pop rivets work well and you can fill the centers if you like and no one will know the difference. Fitting original rivets requires a rivet squeezer or a rivet gun with suitable buck (and some practice if you haven't done riveting before). I put a strip of electrical tape on both flanges to prevent electrolytic corrosion between the steel pan and aluminium shroud. It's a good idea to seam-seal the gully formed at the top of the pan/shroud boundary as it can trap water and encourage rust. The outside of the flanges were painted flat or satin black at the factory to make the flange less noticeable (a detail sometimes missed by even the best restorers).
Edit: I bought a bunch of rivets from an aircraft supplier, but when I realized I'd need a rivet cutter--the available ones were too long--and a squeezer or gun and buck I gave up and used pop rivets on our BN2.
Edit 2: No countersinking necessary; originally, it appears the pan and shroud were mated up and holes drilled through the two. I don't think there was any jig or measurements used as the holes aren't exactly spaced.
Rob Glasgow
Here is a tip I learned the hard way. At least temporarily, fasten the rear flange of the new floor to the bottom of the shroud using either a few rivets or bolts before you weld the center supporting brace to the new bottom. That way you will weld it in the correct location. I didn't do that on my BT7. I just installed the new bottom panel and then welded the brace where it landed on the new bottom panel. When I finally installed the rear shroud, the rear lip of the new floor panel did not line up with the rear shroud flange. I had to cut the brace loose and reposition and reweld it once I had the floor and shroud flanges bolted together. Hope that makes sense.
B
bob hughes
Thanks Bob and Rob, I will make sure I follow those comments up but I am working with the shroud in place so may not encounter your problem Rob unless things go horribly wrong.
First of all I have to cut the old stuff out, just plucking up courage to get the cut off tool out and make a start. All the new stuff has arrived, including a bright shiny aluminium petrol tank and sender along with tank straps and clevis pins to replace the home made stuff a PO had put in. The home made Ali tank must be worth something to someone over here, if they are suffering short arms and long pockets. It worked for me since 2002 when I first bought the old girl, it is a shame that who ever built it could have just spent a bit more time on the details, like a sunken sender area and may be the sunken drain area.
Thanks again
:cheers:
Bob
Rob Glasgow
Bob, Here's a photo of what my boot panel looked like when I cut it out. Just grab the cut off tool and start in.
B
bob hughes
Yup, will do, just got the garden to sort out a bit then I will be into it. I doubt that I will have much more to show than you did, i will post a picture of the debris shortly.
:cheers:
Bob
While solid rivets were originally used, I'm sure there's a high percentage of Healeys today wearing easy to install pop-rivets.
My recommendation would be to use the "closed end" variety, to exclude moisture. A smear of spot-putty will fill the hole where the mandrel popped off, and they will resemble a solid rivet.
Available from numerous sources, so shop around: https://www.aircraftspruce.com/cata...MI1uHRuYDP6AIVhJ6fCh0mKQ-IEAQYBCABEgIamvD_BwE
There are a wide variety of aircraft pop rivets available (usually a goldish Cad-plated color) but one of our airframe mechanics can educate you on them (I used on my rear shroud & for the oil cooler duct/screen).
Rob Glasgow
I used the flat head rivets on my car and if I had to do it again, I would use the pop rivets and fill the holes with filler. I had to cut each flat head rivet to length, make a tool to set the head and go through some careful work to get them crimped. The pop rivets would have been much easier. Here is a photo of the tool I made and the end result, front and back.
B
bob hughes
Thanks every body, all useful information, I will try and escape the clutches of the catering management, tomorrow, who is pursuing me to keep working on the garden, after all a chap needs a bit of R&R, don't you agree. :highly_amused:
:cheers:
Bob
B
bob hughes
Ah I think it may be because I have used google photos, I will try and sort it, though yesterdays ferrous mining revealed even worse dramas.
Mmmm it only works for me when I log onto Google ?
Any Ideas?
:cheers:
Bob
B
bob hughes
OK I have created an Album called Austin Healey, this should be the link
https://photos.app.goo.gl/3wq9g1ZJUc47h4s77
It seams like you have the lot, I will have to create specific albums dealing with each section for the future.
A case of new technology meeting and old head !!
The last image containing my big feet shows the right hand side of the floor in all it's glory mostly fiber glass and paste. The chassis extension leg has a generous helping of the same materials and the rear shroud support rail leg is in a similar state. The rear cross chassis member is nicely rusted at each end where it meets the box boot sections. This is not going to be a five minute job.
:cheers:
Bob
GregW
It looks like you have to share the photos in your google album. I don't use any cloud service anymore because it could end at any time, sometimes without warning.
R Rear Shroud Rivets Austin Healey 6
R Mounting rear shroud rain gutter Austin Healey 14
B BT7 Rear Shroud Austin Healey 2
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
R Rear shroud repair Austin Healey 11
maxwedge5281 two seater rear shroud Austin Healey 15
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
T Help ! Rear shroud measurement Austin Healey 14
5 Rear license plate shroud holes location Austin Healey 4
W BN2 rear shroud holes Austin Healey 2
T Rear Shroud Repair Austin Healey 3
Superwrench Rear shroud sealer Austin Healey 3
Superwrench Healey Rear Shroud Restoration & Tools 0
A who was asking for a bn2 rear shroud? Austin Healey 0
H Rear shroud for 2 seater Austin Healey 10
Barryp Rear shroud removal advice Austin Healey 5
F BN1 Rear Shroud Rivets Austin Healey 8
R BJ-7-Top frame connected to rear shroud? Austin Healey 3
R Holes in rear shroud-BJ7? Austin Healey 1
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
