Rear shroud repair
robolab
I want to repair the edges of the rear schroud of my BJ8. I must manufacture edges stripes as represented in the picture.
I will try to bend the Alu-stripes between hardwoodparts as shown in the example picture. Is it possible and which Aluminium-alloy should I use and which sheet metal thickness I am supposed to choose.
Gerd
attachment.php
attachment.php
Keoke
Gerd !
I forget the thickness but the aluminum is very close to pure which I think is # 6000.
Man that repair strip looks great--:applause:
BoyRacer
The alloy you want is 3003 and the thickness is the same as your shroud... .060". I am assuming that the aluminum in your photo is a very light gauge if you can form that tight of a radius using only wooden forms. I would offer two tips. First, anneal the aluminum as it will make working the aluminum much easier. Secondly, using a shrinker will help you get that tight radius.
vette
What you are trying to accomplish is very much possible. As suggusted by "boyracer" the shape of a new flange is easily done with shrinking jaws. Even relatively inexpensive ones such as bought from Eastwood Co.
You may be able to do it in the wooden form you have made, but the requirement of shrinking the flange as it bends still needs to happen. As you hammer it over the wooden form the edge will buckle and pucker up like a ribbon. Just keep hammering on the ruffles and the metal will be crushed into itself which accomplishes the shrinking. Annealing the aluminum will help the process but if the shrink or stretch is not drastic it may be done without the annealing. If you can't get the shape you want on the wooden form then you will have to get some shrinking jaws. About the thickness of the meta. I don't work with aluminum much, but when I do steel, I like to work with 19 gauge. Recently a metal supplier talked me into trying 22 gauge. I don't like it, it's just a tech too thin. 19 gauge steel holds its shape really well. So I would suggest 19 gauge for the aluminum because I think that will be enough and will be able to be worked fairly easily. Here are some pics of the possibilities. The last pic is a stretched flange because it is an outside radius. Dave.
vette
Here's a pic of welding the flange back on. I had to cut the flange off the new fender to rework the radius because it did not match the car. I then had to weld the flange back on with the fender bolted up to the car because every time I tried welding it off the car, I distorted the fender too much. I eventually made a barrier out of a 6 inch piece of copper so that when I welded i did not burn into the aluminum shroud. Of course this is steel, I have been using a tig welder from my son-in-law but had to give it back. Here I am using a mig. But for aluminum you really need tig. Dave.
BoyRacer
Thin steel is a lot easier to weld than thin aluminum. The rear shroud alloy is actually .062 inch thick. That's approximately the same thickness as 16 guage steel. And that's fairly difficult to weld with TIG even at that thickness. I would not recommend trying anything thinner for those flanges.
But, I have an idea. Forget about trying to do the entire flange as one piece. Do it in sections. Clamp the 1" flange part in a curved hardwood form and bend over just enough material that you can weld into the existing shroud material. I hope that made sense. Without a shrinker, you're gonna have a heck of a time creating that rear section tight radius... instead, trace the desired shape of the flange onto a big piece of aluminum and then you only have to worry about creating a very small flange to weld to.
R
robolab
Thank to everyone for the answers.
Roger, your proposal is exactly what I have planned. The first trials with a 15-inch long piece of 16 gauge aluminum have been very successful. So i will order the necessary aluminium and hardwood.
Gerd
andrea
Richard
I can confirm your procedure - I have saw on a flat plate 1,5m tich of aluminium, some segments of my shroud profile, re-copied on hard board ,
then Mauro TIG welded the segments over the oldest rest of aluminium of the shroud, not easy but I can follow the original shroud profile and in some cases I can also have the same bolt holes traces-
At the definitive rebuilding, I put over the conection a lot of Lityum grease (water resistent)to insulate the different metals,and avoid eletrolitic reaction
R
robolab
After a first test, I decided to make the side pieces of two parts. The first parts of the side pieces (LH and RH) I have bent in the wooden template The photos show the wooden template and one of the manufactured Curved sections.
attachment.php
attachment.php
BoyRacer
That sure looks pretty. Questions: What kind of wood are you using for the forms and is the alloy .062" thick?
R
robolab
I used an existing 2 cm thick beech plywood board, but i think you also can use other hardwood boards. The alloy material thickness is 1,5mm (0,059"), that is a common thickness in Germany.
T Rear Shroud Repair Austin Healey 3
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
R Rear Shroud Rivets Austin Healey 6
R Mounting rear shroud rain gutter Austin Healey 14
B BT7 Rear Shroud Austin Healey 2
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
maxwedge5281 two seater rear shroud Austin Healey 15
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
T Help ! Rear shroud measurement Austin Healey 14
5 Rear license plate shroud holes location Austin Healey 4
W BN2 rear shroud holes Austin Healey 2
Superwrench Rear shroud sealer Austin Healey 3
Superwrench Healey Rear Shroud Restoration & Tools 0
A who was asking for a bn2 rear shroud? Austin Healey 0
H Rear shroud for 2 seater Austin Healey 10
Barryp Rear shroud removal advice Austin Healey 5
F BN1 Rear Shroud Rivets Austin Healey 8
R BJ-7-Top frame connected to rear shroud? Austin Healey 3
R Holes in rear shroud-BJ7? Austin Healey 1
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
