BJ7 Hood frame mounting plate
  • Thread starter Deleted member 26968
  • Start date
Hi.
Need some advice.
Does anyone have a photo showing the configuration of the hood frame mounting plate on the B post. I am trying to get the hood alignment against the window correct and looking at the mounting plate I have a spring over a bolt on one side of the car and none on the other side. Which is correct and if I need another spring or spacers, who sells them?
I have also just learned there is a huge spring fitted from this hood mounting plate to the floor. Neither of my cars had any sign of floor attachments for this so I
wondered if it is really necessary. There is such a short lever arm I really can't see a spring having any real affect given the weight of a fully loaded hood. None of the Triumphs have sprung loaded hoods.
Also for the hood drain channel pipes, none of the suppliers show whether to over-drill the hole size and fit a rubber grommet. Can you advise what the original procedure was and if all five holes are really required. One of them is right over the driveshaft. Fact is, I hate the idea of drilling all those holes in my brand new paintwork as I hadn't planned to drive the car during a tsunami!
Cheers
Barry
Healey Nut
Just behind the door openings on the sill portion should be a triangular plate with a hole in for one end of the spring, they will be hidden by the rear trim panels . The other end of the spring goes into that tab of the twisted bar next to the tonneau rod support shown on your pics . The springs are covered with a sleeve of armacord .
For the drain holes . The ones going through the wheel arch don’t have grommets you can just caulk seal them if you like . The ones going through the rear seat deck have grommets .
No I don't have any such plate and looking on Kilmartin's website I couldn't find one there. I could always screw a plate to the sill but until I get the springs I won't know the dimensions.
I have drilled and fitted the centre drain pipe with a grommet. I am hoping that I can get away with only three drain holes. But when I look at that channel and consider the risk of it overflowing in a storm I can see why there are so many.
Do you know of any other cars with a rain gutter on the inside?
Cheers
Barry
Healey Nut
I cant find any pics of the plate but it’s not complicated . Maybe 3” wide at the base triangulated to 1 1/2” tall with a small hole for the spring hook but they were welded to the inner sill in that small space where the dogleg of the trim panel comes down to the floor .
The springs assist with lifting of the top frame so as you lift on one side of the car the frame doesn’t twist . It’s not that it’s heavy .
If you always lifted the top with two people one each side there would be no need for them .
if your car is already painted then you will probably have to just bolt/sheet metal screw them to the inner sill .
grimes6
The plate is AH422 on Kilmartins site. If you click on the image it will show you the wrong photo but it is listed as "Softop spring anchorage bracket - to inner sill assembly"
Regards,
Greg
Exzcellent.
Many thanks for the plate details. The hood springs make sense now.
Barry
Riquet1963
Hi.
Need some advice.
Cheers
Barry
Hello Barry or others
Actually I am renovating my frame and need to rebuild it with an original shape..
Have you more precise pictures of this zone?
Many Thanks in advance and merry Christmas
BR
Eric G
gonzo
Aluminum shims stacked underneath the two frame anchor points help with hood/frame adjustments. The sims are about 1/16in. thick each and on my car (BJ7) one is installed on the driver's side, while two are stacked in the passenger's side.
B BJ7 hood frame dimensions Austin Healey 0
B Best screws for woodwork to BJ7/8 hood frame Austin Healey 5
R New Hood for BJ7 Austin Healey 3
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
chicken Hood Bow BJ7 and hood fit Austin Healey 6
chicken help with hood mounts bj7 Austin Healey 0
maxwedge5281 bj7 hood latch pull Austin Healey 6
B BJ7 hood installed Austin Healey 6
John Loftus Early BJ7 Hood [top] request Austin Healey 5
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
