1963 bj7 rear interior trim
maxwedge5281
still working on the above car. previous owner had installed new non factory carpet. and, in the process removed the rear seat pans and covered over the area with a piece of properly folded sheet metal. they did a nice job but i have removed this metal, ordered new seat pans and a new factory type carpet set. my vinyl trim is good but they also removed the small vinyl covered bulkhead behind the seats. the factory top folds down behind this area. does any of our suppliers offer just the vinyl covered piece without purchasing the entire vinyl interior pieces? also does anyone have a good detail picture of this item. maybe i could buy the vinyl and fabricate a proper piece? any help is appreciated.
HealeyRick
It's not a bulkhead, but a fold down seat squab. The squab is upholstered in a pleated pattern.
I don't know of any place that sells the squab base. IIRC the squab consists of a piece of plywood with foam attached to the front. John Skinner sells an upholstery kit for the rear squab and seat pans: https://austin-healey-trim.co.uk/au...-armrests/rear-seat-kit-leatherfaced-3000-bj7
maxwedge5281
maxwedge5281
rick, is the squab hinged to fold down over the two rear seats. most likely could be easily fabbed if i had any idea of what the squab looks like beneath the covering material.
bob hughes
I can not be certain, but I think that the squab folds forward a bit to get the soft top into the space, but does not fold all the way down. I fitted a pair of hinges that I altered to suit and mine almost folds down but is probably incorrect.
B.T.W. do you have a photo of the rear internal quarter panels and how they fit at the squab holding bracket, I think that the bracket is fixed over the quarter panels but I can not be certain.
:cheers:
Bob
Bob
maxwedge5281
maxwedge5281
bob, no i do not have any idea of how the piece is fitted not how it works. i just ordered the end pieces from moss and hope to be able to determine how the upholstered piece might fit...i think that i can fabricate and buy the upholstery for that piece. if you have a pic available, it would be greatly appreciated.
BG 62AH
Possibly these pictures may help. My car is a BJ7, but it seems that a previous owner used some BJ8 interior pcs on it. The condition of my interior was very poor when I got the car. The brackets pictured hold the cushion up for the rear seat back support. The cushion is on hinges, it folds partially forward for raising/lowering the soft top. It does not seem to fold all the way down like a BJ8.
Hope they help.
bob hughes
Max
Not clear on what you require, photos of the rear quarter panel? how the squab bracket fixes on the inner rear wing? my home made hinges for the squab? or all three
:cheers:
Bob
bob hughes
The first three shots are of a BJ8 rear quarter panel showing the weather strip termination front and rear of door.
The next two are of the rear of my BJ7 showing a modified hinge and the bracket at the back of the squab.
In reality I think that the hinge fixing at the back of the squab should be inside the covering, but I am not sure, I made the hinge to be of set so it fixes on the underside of the squab as well.
Looks as if the rest of the attachments did not come out. :wall:
https://www.britishcarforum.com/bcf/attachment.php?attachmentid=32350&stc=1&d=1395348328
jpg.gihttps://www.britishcarforum.com/bcf/attachment.php?attachmentid=32355&stc=1&d=1395348328f 0https:/https://www.britishcarforum.com/bcf/attachment.php?attachmentid=32354&stc=1&d=1395348328/www.britishcarforum.com/bcf/attachment.php?attachmentid=32352&stc=1&d=139534832821.jpg (187https://www.britishcarforum.com/bcf/attachment.php?attachmentid=32353&stc=1&d=1395348328
https://whttps://www.britishcarforu...chmentid=32359&stc=1&d=1395349031d=1395349031
maxwedge5281
maxwedge5281
bob, if possible all three. i dont have any of the parts to go by. i did order some hardware today. thank you very much....
British_Recovery
Bronze
Hi,
The BJ7 rear squab panel is held in place with two footman's loops (same as chrome loop for the spare tire strap in 4 seaters) fitting into rubber anchors (same as bonnet rod and boot lid rod retainers) on the steel vertical supports. There is one loop on each vertical edge of the rear of the squab, and it's just a push-in fit, with no hinges. There's a good illustration on the AH Spares parts list.
Good luck, Bob
bob hughes
maxwedge5281
maxwedge5281
thank you very much for all the pics and info>>>>
bob hughes
Good news all
I have been able to confirm from two separate Healey specialists that the rear quarter panel trim on the BJ7 does get fitted behind the holding bracket at the rear of the squab.
Remove the seat belt fixing and the bracket from the inner wing, fit the quarter panel and all seat belt and bracket fixings pass through it.
Further more, I enquired about the seat belt fixing as mine is a single point fixing ( the early cars had a two point fixing to help avoid a clash with the squab) - no problems but there may be a possibility of a clash with the squab. As the squab does not fold flat anyway, this will not be a problem to me.
:cheers:
Bob
maxwedge5281
maxwedge5281
bob, sorry to continue to ask, but what point/points are you listing regarding the safety belts. my bj7 belts have a threaded female on the tunnel and an eyelet through the driver floor at the door opening. are these the correct points for the safety belts on a bj7? thanks again for your help!
bob hughes
No problem Max
The female thread on the tunnel is fine.
The bracket bolted to the floor near the door is fine - the detail should have a spacer on the top of the floor and a reinforcing piece on the underside of the floor, there should be a pin passing through the bracket picking up the hole in the seat belt fixing and unless you have the quick release variety, there should be a split pin fitted to prevent the main pin from falling out. I have used a K or R clip as it is easier to remove than the split pin.
I was referring to the third fixing position. On your photos of the internal rear wings ( fenders) you can just see what look to be two stumps projecting from a rectangular blister, they should be studs and they pass through the quarter panel trim and the belt fixing has two holes at this point. There should be two domed headed huts to hold the seat belt fixing.
:cheers:
Bob
HealeyRick
The bracket bolted to the floor near the door is fine - the detail should have a spacer on the top of the floor and a reinforcing piece on the underside of the floor, there should be a pin passing through the bracket picking up the hole in the seat belt fixing and unless you have the quick release variety, there should be a split pin fitted to prevent the main pin from falling out. I have used a K or R clip as it is easier to remove than the split pin. Bob
What Bob is describing here is the BMC seat belt bracket that attaches to the floor next to the inner sill. Maxwedge has said that he has an eyelet bolt that was used as a fixing point for the outer belt, which will also work if reinforcing washers are used. The BMC bracket is available here https://www.ahspares.co.uk/austin-h...Seats-Safety-Harnesses/BRACKET-seat-belt.aspx If you go to John Sims's excellent Healey6 site here: https://www.healey6.com/technical.htm and scroll down to the "Safety" section you will find a link to a pdf entitled "Seat Belt Installation." This is a BMC sheet that will provide the locating measurements for the seat belt brackets.
The fixing points for the shoulder belts are as Bob described. If you decide to purchase shoulder belts, make sure they have the correct fitting that will attach to the two studs Bob referenced.
maxwedge5281
maxwedge5281
thanks very much for all the insight and help. does the healey use a three point system for the safety belts? i have located three points in my car...tunnel female mounting, sill area with a reenforced mounting plate, and the two male threaded studs on the quarter panels... thanks again!
bob hughes
Max
Yes there are three fixing points and I think that you have them all, when you refer to the sill area, I am assuming that you are referring to the floor next to the sill and at the big end of the tear drop shape depression in the floor panel.
:cheers:
Bob
maxwedge5281
maxwedge5281
yes i believe that i have the three points. i suppose that there are proper healey belts available for the three point mounting. is this customary or do most owners use just lap belts?
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
pbraun For Sale 1963 Austin-Healey 3000 BJ7 Austin Healey Classifieds 5
me61ic 1963 BJ7 Resto Latest Austin Healey 2
maxwedge5281 1963 bj7 carpet install and mirrors Austin Healey 3
maxwedge5281 wanted: hardtop for a 1963 bj7 Austin Healey 29
A 1963 BJ7 - 6 months of hard work Austin Healey 12
D 1963 BJ7, I found a complete car Austin Healey 8
F 2nd set of detail questions: 1963 BJ7 Austin Healey 21
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Hamish Racing Period racing 1963 video Jaguar 0
Hamish Racing Period racing 1963 video British Motor Corp 0
Hamish Racing Post-War Other Period 1963 racing film Triumph 15
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
dougie 1963 Sebring Big Healey 57 FAC Austin Healey 4
M Wanted MGB grill 1963 to 1969 MG Classifieds 2
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
M 1963 TVR Grantura TVR 6
J 1963 Austin Healy "Sprite" Value Austin Healey 7
J Found a 1963 BJ8, by the serial number, built in October of 63 Austin Healey 26
S TR4/4A Searching for 1963 TR-4 CT 13164L Triumph 2
D MGB Ready to install the head - 1963 rebuild MG 0
D MGB 1963 MGB engine rebuild MG 4
T TR4/4A 1963 Triumph TR4 Triumph 11
mgbman1964 MGB New seat rails for my 1963 MGB MG 3
Editor_Reid Caption Assistance - 1963 Sebring Photos Austin Healey 8
DrEntropy 1963 Ford Fairlane Spotted 1
JohnCarey Bettie is my 1963 E-Type FHC Jaguar 1
R 1963 Sprite MKII 1000 info needed Spridgets 2
HealeyRick Healeys at Sebring 1963 Austin Healey 1
E MGB VALUE OF A EARLY 1963 MGB MG 4
T TR4/4A 1963 TR4 project Possum Bottom Triumph 5
coj oil pressure 1963 engine [29F] Austin Healey 7
T Post-War Other 1963 triumph "vitesse sport 6 " roadster - $1500 Triumph 5
HealeyRick 1963 Amateur Sports Car Racing Video Spridgets 3
HealeyRick 1963 Amateur Sports Car Racing Video Austin Healey 0
af3683 TR2/3/3A TR3B - Register it as a 1962 or 1963? Triumph 19
vping MGB 1963 MGB Barn Find - Here are all the pics. MG 19
vping 1963 Iris Blue - First pic MG 13
M MGB 1963 MGB for sale MG 0
JimmyG Spitfire 1963 Right Hand Drive Spit Triumph 5
tony barnhill MGB 1963 MGB Found in Mississippi... MG 19
O Parting out the 1963 Midget Spridgets 17
tony barnhill 1963 Midget Body Up-date Spridgets 7
M 1963 Sprite MkII Seats Spridgets 2
tony barnhill 1963 Midget Tire Size Spridgets 10
